Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 27th July 1998, 03:25 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Read This! Brute Force Validation - Difficult to show 10-year calibration cycle is sufficient
A good read:
Subject: Re: Calibration/Pfrang/Volker/Pfrang
What is "validation by brute force"?
Validation by brute force means that you try a tool in your process and you see if it works; if it works, then you have validated that tool by brute force. It is also known as trial and error. For example, let's say you're repairing a customer's car, and the shop manual says to use a 5 mm wrench. You've never calibrated your 5 mm wrench, so you don't know if it's really 5 mm or not. But you grab it anyway and discover that it works. You have just validated that tool by brute force, because you have tried it and found that it works in your process. You don't care if the wrench really is calibrated to 5 mm or not, because you know that it fits the bolt you're trying to remove and that's good enough.
The same goes -- potentially -- for any tool in any process: given enough time, money and effort, you could, in theory, validate every tool in every process by brute force trial and error. The problem is that some tools and some processes are too expensive, time consuming or dangerous, to validate by brute force trial and error.
>> If the manufacturer recommends
>> that you recalibrate a tool annually, but you find it perfectly adequate
>> in YOUR process -- to revalidate that tool every decade, then you are
>> perfectly justified in revalidating that tool every decade.
> Won't it be little difficult to show 10-year recalibration is
>adequate??? Say you do happen to have 2 calibration records for one
>instrument 10 years apart, and they show it's remained in calibration--
>is that one sample of a test of the 10-year-hypothesis statistically
>valid? If the manufacturer has a 1-year guideline, shouldn't you start
>from there, and then maybe see if you can lengthen it?
Your questions cannot be answered in the abstract. You have to use a specific example, because every situation is unique. With some tools, in some processes, it is perfectly acceptable to go 10 years between validations; with other tools, or other processes, it is not. The rule is to start with the manufacturer's guideline (or your own experience, if there is no guideline), and then let your (DOCUMENTED!) data and your common sense determine what is reasonable in YOUR process. Maybe ten years is OK, maybe it's not.
Also, I did NOT say that you only needed to do one validation and then you could immediately jump to a ten year duration. In most situations, you should indeed start with a shorter duration, say one year, and use that duration for a year or two until you gain enough (DOCUMENTED!) experience with YOUR particular tool in YOUR particular process to justify extending the cycle. All I said in my posting was that IF you have the (DOCUMENTED!) data to justify extending a validation cycle, then there is nothing necessarily wrong with doing so, because this is definitely NOT an ISO non-conformity.
Never forget, however, that there is a danger of extending the validation cycle too far: the longer the cycle, the more likely it will be that: (a) a tool WILL BE out of spec at its next validation (assuming drift is an increasing function of time); and (b) you will have shipped a lot MORE PRODUCT in the interval since the last validation. Therefore, a long validation cycle not only increases (a) the PROBABILITY that you will have to do a recall; but it also increases (b) the TOTAL NUMBER OF UNITS involved if a recall is required. Your exposure to financial loss (due to shipping defective products) therefore increases EXPONENTIALLY as you lengthen your validation cycle! Keep that in mind before you kick your validation cycle out to ten years.
Oh, yeah, and remember that the data you use to justify your validation cycle must be DOCUMENTED!
-- Doug Pfrang
Sponsored Links
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calibration and Preventive Maintenance - What is meant by Calibration Life Cycle JHONNYMEDICO Student Research Questions - Any Educational Institution 2 13th November 2009 01:22 PM
Tri-annual TS16949 continuous assessment (3 year cycle) jeffb ISO/TS 16949 - International Automotive Quality Systems Standard 2 12th February 2007 07:16 PM
Torque Wrench Calibration - Difficult time with repeatable measurements jeremiah ISO 17025 - Calibration, Measurement Gages and Test Laboratories 12 10th August 2006 06:39 PM
Recertification of ISO 9001 QMS? Three year cycle amanbhai ISO 9001 - Quality Management Systems Standard 45 28th April 2006 05:19 PM
Are measuring equipment manufacturer calibration certificates (certs) sufficient? deuce QS-9000 - American Automotive Manufacturers Standard 6 4th June 2004 12:53 PM
The time now is 01:41 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
