Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th May 2004, 11:00 AM
jj1234 jj1234 is offline
Registration Date: Feb 2004
Karma Power: 24
jj1234 has less than 100 Karma points so far.
Default Do the inspection stages in flow chart also need to come out the FMEA?
Dear sirs;
I have one question regard to flow chart vs PFMEA. As we knew, the PFMEAs should come out with flow chart step by steop. If one flow chart like as below with inspection stahes, do inspection stages also should have its FMEA or we just skip inspection stage when come out the PFMEA.
Material incoming inspection -->Process 1-->inspection A-->Process 2-->Inspection 2
Hope you can give me the suggestion
Sponsored Links
Old 15th May 2004, 02:00 PM
Al Dyer's Avatar
Al Dyer Al Dyer is offline
Mod...
Registration Date: Mar 2003
Thanks Given to Others: 4
Karma Power: 46
Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.
Send a message via AIM to Al Dyer
Default
Welcome,
I would say that flow charts are the visual map of what happens. The PFMEA is the thought process (documented) leading to the actual process that can be delivered by a flow chart.
Al...
"Para ... Bellum"
Sponsored Links
Old 15th May 2004, 05:22 PM
Govind's Avatar
Govind Govind is offline
Registration Date: Apr 2004
Thanks Given to Others: 13
Karma Power: 50
Govind has disabled his/her Karma.
Default
Originally Posted by jj1234
Dear sirs;
This is a tricky question.
Example: If the inspection step is a visual inspection, we do not consider it as a step to go through failure mode, cause, effect, severity, Occurrence and detection.
If the process involve clamping the part or loading in an inspection fixture, then Yes. This may cause certain failure due to excessive clamping or scratching a polished surface.
I suggest,we have to evaluate the situation and decide whether the inspection step should be included in a PFMEA.
Regards,
Govind.
Old 17th May 2004, 09:25 AM
Bill Ryan's Avatar
Bill Ryan Bill Ryan is offline
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.
Default
Welcome to the Cove
All "Sequence" steps shown in the Flow Chart show in both my PFMEAs and Control Plans. Questions for those not doing so - Can an operator misread a gage? Can a gage "misread" a part? Regarding visual inspection - Are the visual controls adequate/current? These three questions are "Potential Causes" in the PFMEA (at least in my methodology) relating to "Failure Modes" of passing a defective part or rejecting an acceptable part.
Just my
Bill
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
Old 17th May 2004, 09:30 AM
The Taz!'s Avatar
The Taz! The Taz! is offline
Courtesy Access
Registration Date: Nov 2003
Karma Power: 46
The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.The Taz! is appreciated, and has over 500 Karma points.
Send a message via AIM to The Taz! Send a message via Yahoo to The Taz!
Default
Originally Posted by Bill Ryan
Welcome to the Cove
Just my
Bill
I'm with you Bill. . .
If something is over engineered. . . it will probably be under manufactured! (Jim Eustace 1993)
Old 17th May 2004, 09:51 AM
ralphsulser's Avatar
ralphsulser ralphsulser is offline
Quality Team
Registration Date: Jun 2002
Thanks Given to Others: 87
Karma Power: 127
ralphsulser is appreciated, and has over 1700 Karma points.
ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.
Default
I agree with Bill and Taz, each step of the inspection stage contribute to the probability of detecting a failure, and visual inspection should be considered since it is part of the process, and shown on the flow chart. Visual criteria must have been established for inspection for accept/reject correct?
"Nothing is constant except change"
Old 17th May 2004, 10:15 AM
The Taz!'s Avatar
Courtesy Access
Karma Power: 46
Default
Also consider customer input regarding the Visual Inspection Detection score. Some customers will not allow a score less than a 5 for visuals. This should be defined during the APQP process.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Risk Analysis using FMEA Process Flow Chart - Health Care Information System medalex FMEA and Control Plans 6 2nd October 2009 11:14 AM
Flow chart, FMEA, Control Plan for cable assembly for Automative industry mooi mooi ISO/TS 16949 - International Automotive Quality Systems Standard 3 10th October 2008 07:00 PM
Process Flow Chart vs. Process Flow Diagram? Pages 38-39 in the APQP Manual AirAusquin FMEA and Control Plans 3 29th August 2007 01:42 PM
Software which links Process FMEA (PFMEA), Control Plan and Flow Chart Jose Luis de la Cruz Quality Assurance and Compliance Software Tools / Solutions 4 6th January 2005 02:38 AM
Flow Solder Control Chart - I believe I need an Xm-R chart Chris May SPC Monitoring and Statistical Analysis Techniques 3 13th May 2002 10:48 AM
The time now is 03:11 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
