Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th August 1998, 02:02 PM
Tony Grover
Unregistered Guest
Posts: n/a
Let Me Help You What is the best procedure for calibrating / certifying our Calipers?
We primarily use calipers for inspection. We have a set of gage blocks certified to NIST. What is the procedure for certifying our Calipers. We are going for ISO9002 in 98 and QS9000 in 99. I know we have a lot to learn in this area. Is anyone willing to help us get started down the right track.
thanks.
Sponsored Links
Old 19th August 1998, 09:18 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
You have two choices for your calipers:
1. Send them out for calibration.
2. Work up a procedure for calibation and use your gage blocks to verify the calibration of the calipers.
How's that for starters?
Sponsored Links
Old 20th August 1998, 12:10 PM
jcl
Unregistered Guest
Posts: n/a
Default
And to add .. if you use the 2nd method (recommended .. thats what we do) make sure you have a procedure to regularly send out the gage blocks for calibration to NIST.
Old 21st August 1998, 07:37 AM
SCOTT SNYDER
Unregistered Guest
Posts: n/a
Default
ALSO MAKE SURE YOU HAVE A CYLINDRICAL RING GAUGE AND ENOUGH BLOCKS TO CHECK THE COMPLETE RANGE OF ANY CALIPERS YOU HAVE(ie. 12",6", etc.)
Old 22nd August 1998, 07:48 AM
Marc's Avatar
Karma Power: 605
Default
Or at least the ranges or points you use.
Old 9th May 2005, 01:37 AM
sarasheed sarasheed is offline
Involved in Discussions
Registration Date: Apr 2005
Thanks Given to Others: 3
Karma Power: 19
sarasheed has less than 100 Karma points so far.
Default
We are using Stick Type of Michrometers to measure the Internal Diameters from 50 mm to 1500mm.This michrometer consists of a Michrometer Head and set extension rods which if assembled will read upto 1500 mm.I want to know how to calibrate this type of Michrometer.At preselnt we calibrate the Michrometer Head for the Pitch deviation and and attach the reading of each individual extensiln Rod in the calibration certificate .This Certificate is will be there along with the Michrometer during its use.
I request somebody to react to this method.Is it serving the purpose of calibration?.Can somebody suggest any other method.
Old 9th May 2005, 05:00 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
The basic approach seems OK, although I would point out that you also need to take into account what is known as "wringing", that is the joining of gage blocks - or in this case rods - to obtain a given length. The normal value given to ringing is 0.00005 inch per wringing. Thus, joining five rods will have four junctions, or wringings, with a total number of 0.0002 inch.this goes into the uncertainty calculations also.
There are likely some other sources of error you should take into account, but aside from temperature and RH it would be difficult to say which, without knowing the specific situation.
Hope that helps.
Hershal
Moderator's comment:
"Wringing" is the action of putting two blocks or rods together and giving a slight twist to "wring" the air out from between the blocks and form a vacuum which helps hold the blocks together from the outside air pressure pushing the blocks together. In some cases, the block can be suspended upside down and will not separate. To disengage the blocks, they are "unwrung." -Wes Bucey
Last edited by Wes Bucey; 9th May 2005 at 05:28 PM. Reason: change "ringing" to "wringing" (the correct spelling)
Old 12th May 2005, 12:22 AM
Karma Power: 19
Default
Thanking you for giving reply to my doubt about calibration of Stick type Inside Michrometers.
S.A.Rasheed
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calibrating a Gage Block In-house with Calibrated Digital Calipers ollie107 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 7 18th August 2009 10:19 PM
Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks Rustedamy ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 9th April 2008 05:38 PM
Help: Procedure for calibrating files used to check hardness Grizz1345 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 23rd September 2004 02:31 PM
Calibrating .001" resolution Dial Calipers - Calibration and safeguarding procedure apestate ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 18th November 2003 05:05 PM
Calibration Procedures for checking and certifying micrometers and calipers mibusha ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 10th March 1999 08:53 AM
The time now is 06:19 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
