Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
2nd July 2007, 02:37 PM
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,947
Karma Power: 1430
Re: Free GD&T font for Word and Excel
In Reply to Parent Post by Rob Nix
I don't know if I'll be sent up the river for this, but here you are:
How do I integrate these symbols in my document?
I can open the zip file, and what do I do now?
Thanks for your help.
4th July 2007, 07:45 PM
Email Address Invalid or Rejected by Recipient System
Registration Date: Mar 2007
Thanks Given to Others: 18
Karma Power: 0 Karma: 99
In Reply to Parent Post by Stijloor
A quick question: does this font set include the "Datum Feature" (ISO) symbol? This particular symbol was changed from the previous GD&T Standard version.
I am not sure what your interpretation of "Datum Feature" (ISO) symbol is? Are speaking of the "triangle" to note a Datum feature? If so, no it is not there. I also noticed no use of the symbol U (similar to M for MMC etc.)
In the link I provided you can download the program under a trial version and see if it fits your needs.
For creating AS9102 form3 and other reports I have found it invaluable!
Reason: added info
4th July 2007, 07:48 PM
Simply copy and paste the TTF file into your Fonts folder, this will automatically install the font.
Typical path:
" C:\WINDOWS\FONTS"
Once installed it will be ready to use in most applications. Here is an Excel application example that is typical to most applications.
In Excel, find the Font menu in the upper menus of Excel menu bars. From the menu you select the appropriate font, in this case " gdt_____.ttf"
You will have to get used to remembering Key codes to use the font.
Such as, example, pressing the following keys while holding down the "ALT" key will produce this character " Ø".
ALT 0 2 1 6
(Spaces are for clarity only).
In the program I suggested ($50.00) you select the desired character from a menu with a simple mouse click. Installing the IMS.TTF font is the same as above.
Thanks to QC Rick for your informative Post and/or Attachment!
4th July 2007, 08:43 PM
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
In Reply to Parent Post by QC Rick
Typical path:
" C:\WINDOWS\FONTS"
ALT 0 2 1 6
Note that if the font is just copied into the fonts folder you might have to reboot before programs will "see" it, because fonts are enumerated at boot time (which is why getting rid of some fonts can speed up the boot process if you have a lot of them). Also, you can just open Character Map and select/paste from there. In Win XP, it's Start/AllPrograms/Accessories/System Tools/Character Map. Or even simpler, Start/Run and then charmap. No $50 required.
We aim to please. You aim too, please.
Thank You to Jim Wynne for your informative Post and/or Attachment!
10th September 2007, 11:43 AM
Getting Involved (6 to 9 Posts)
Registration Date: May 2005
Thanks Given to Others: 178
Karma Power: 33 Karma: 10
Thanks for posting the font.
Regards
11th January 2008, 04:33 AM
Registration Date: Jan 2008
Karma Power: 22 Karma: 10
Muchas Grasias,,,
11th January 2008, 07:00 AM
Involved - Posts
Karma Power: 45
The procedure is :-
1) Unzip the Zip file to any folder (Let us say C:\)
2) Able to see the file " gdt_____.ttf" in the C:\ folder
3) Open Control panel ,or Type "Control" in the Start >>> Run
4) After opening COntrol panel GO to Fonts , open it .
5) From Menu, "File" Select "Install New font" , In the Pop up , Locate the
path ( As per above example:- C:\ )
6) Select the " gdt_____.ttf in the list of fonts. and Click "OK"
7) That it.
8) Open the Word or excel , you will be able to see the Font as "gdt"
Sathish
Thank You to sathis for your informative Post and/or Attachment!
3rd June 2008, 03:03 PM
Registration Date: Jun 2008
Karma Power: 21 Karma: 10
Thanks Rob, I think. I have downloaded the .zip file to my desktop and then attempted to save it to C:\Windows\Fonts. However I get an error message because it is still zipped or the file format is incorrect. How do you unzip the file, doesn't XP automatically unzip. Has anyone else had this problem?
Forum Posting Settings
