26th September 1998, 08:44 PM
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0 Karma: 40
What is the best gage equipment to measure an ID bore? Coordinate Measuring Machine?
What is the best equipmenbt to gauge an ID bore; what gauge will give accurate Gage R & R studies as the best possible gauge? Is a Sunnen Gauge better than the CMM for ID's when there are problems with roundness?
28th September 1998, 07:45 PM
Can you tell me where I can get a 3-point bore gauge and how much?
Thanks, Dawn
29th September 1998, 01:38 AM
DAWN,
THE FOLLOWING ARE ONLY MY VIEW POINTS FROM MY PERSONAL EXPERIENCE.
1) THE CMM WILL PREFORM ROUNDNESS BETTER
2) THE SUNNEN GAUGE IS NOT AS GOOD AS A 3-POINT BORE GAUGE.
HOWEVER THE BORE GAUGE WILL SHOW YOU WHERE YOU ARE OUT OF ROUND. IF YOUR CMM DISPLAYS GRAPHICS ON MULTIPLE POINT FEATURES. IT WILL ALSO SHOW YOU WHERE YOU ARE OUT OF ROUND.
3) THE BORE GAUGE SHOULD GIVE A BETTER R&R BECAUSE YOU CAN CONTROL THE POINT OF MEASURE EASIER.
29th September 1998, 07:35 AM
DAWN,
MOST ALL OF THE MAJOR MANUFACTURERS CARRY 3-POINT GAUGING. BEFORE YOU RUSH OUT AND BUY REQUEST INFORMATION FROM SEVERAL OF THEM. DEPENDING ON YOUR PROCESS THERE ARE DIFFERENT TYPES OF 3-POINT MEASURE. DO YOU HAVE A MANUAL OR CNC-CMM? IF IT IS CNC YOU CAN CONTROL WHERE YOU MEASURE AND COULD DO SOME SAMPLING BEFORE INVESTING IN A GAUGE THAT MAY NOT BE NESSARY. CHECK ALL YOUR OPTIONS AND PRICING CAN BE DONE THROUGH YOUR LOCAL INDUSTRIAL SUPPLY HOUSE.
29th September 1998, 09:17 PM
Sunnen gages have 3 prongs and can measure tenths. Why would a bore gage be more accurate?
30th September 1998, 07:27 AM
WHAT MODEL # SUNNEN ARE YOU USING?
3rd September 2005, 09:56 AM
Gage Crib Worldwide
Registration Date: Aug 2005
Thanks Given to Others: 14
Karma Power: 46
Originally Posted by Dawn
What is the best equipment to gauge an ID bore;
The first reply question is what is the tolerance of the bore? Product can be over measured. Given enough tolerance, GO/NOGO plug gages may be sufficient.
Again the tolerance of the bore plays a part in determining "best" for this application. A CMM should not be used to measure a counterbore for a cap screw.
Remember that not all out of roundness problems are bilobal. Some are tirlobal and others are multilobal. More than one measurement tool may be needed to determine the lobality pattern of the product. Once established, a tool designed to detect that specific defect can be chosen.
3rd September 2005, 10:52 AM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Very good advice, and I'll add the fact that the best way to avoid roundness issues in bores is to fix the process. Often there's an easy fix, as roundness issues can usually be traced to fixturing and/or tool wear problems.
