Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th September 1998, 02:34 PM
copelams
Unregistered Guest
Posts: n/a
Question IEC25 - What is the interpretation on "equivalent" National Standards?
What is the interpretation on "equivalent" National Standards? I belive that ISO10012, ANSI/NCSL Z540-1-1994, or MIL-STD-45662A applies. I am aware that MIL-STD has been superceded, but it doesn't mean obsoleted does it?
Sponsored Links
Old 20th September 1998, 08:12 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
OK - now. By "equivalent" National Standards I assume you mean of calibration standards, correct?
If so, they are just asking that you present a reasoning for the standard you use. Obviously NIST has standards for just about everything. But theoretically if you came up with a measurement of a previously undefined 'aspect' or 'quality' YOU could define the standard. Units of length, light, mass, etc. are all pretty much taken, by the way...
You can use any standard you like - even a discontinued or obsoleted standard - as long as your system supports it (as long as it is documented) and 45662A is no exception.
Sponsored Links
Old 21st September 1998, 08:41 AM
copelams
Unregistered Guest
Posts: n/a
Default
Thank you for the input. I would think that an obsolete standard would still apply. In fact, the "new" standards state that for comparison, review 45662A!
At any rate, the term "National equivalent" is a little ambiguous and the auditor we use wasn't too clear about whether 45662A was "OK". I wanted to pose a justification discussion, but I wanted some feedback from someone else before I firmly stood my ground. Thanks for the help!
Old 30th September 1998, 07:30 PM
Dawn Dawn is offline
E-Mails Invalid or Rejected
Registration Date: Sep 1998
Karma Power: 0
Dawn has less than 100 Karma points so far.
Default
The ISO 10012 is not taking new posts so I will post this here. How do I put measurement uncertainty into a procedure? Just exactly what would be the definition and do I have to prove and document the uncertainty on every gage?
Old 30th September 1998, 10:20 PM
Marc's Avatar
Karma Power: 605
Default
Dawn - I saw you posted your Q in the ISO10012 forum. Why do you say it (I assume you mean the forum) is not taking new posts? I just did a test post (which worked fine), and your message is there.
Old 30th September 1998, 10:35 PM
Marc's Avatar
Karma Power: 605
Default
Back to the subject - OK - by standards you mean specification type stuff as opposed to measurement standards. I sorta touched on that in the last sentence of my response above but didn't fully understand the question...
You ask yourself the intent of what you're doing (eg. Calibration). The bottom line intent it to ensure your measurement system (QS9000 is now high on the MSA band wagon) is calibrated to a 'standard' so that we all measure the same inch. Method of measurement becomes more important with MSA (as an element - and there are many 'elements' of MSA).
You ask yourself the intent of what you're doing (eg. Calibration) and the intent is to have a defined system with certain characteristics of the system as 'required' and defined by a'spec' (if you will). In this case we have ISO10012, ANSI/NCSL Z540-1-1994, and MIL-STD-45662A. They each provide some guidelines and have similar, and in same cases the exact same, requirements. They each provide requirements which cause the system to meet the root intent.
I'm going to assume the auditor had simply never had MIL-STD-45662A in his past experience which explains why the auditor was 'fuzzy' about it. This is not unusual.
The last issue is the 'equivalent international standard' where the US has a calibration spec (the old MIL-STD-45662A for example) and say a Brazilian 'equivalent' (I have no idea what Brazil has). As long as they each meet the 'intent', you can use either - technically. Another example that may be closer to home is the ISO9001 standard where it is the same in all countries as far as text goes but is (typically) renamed or renumbered. If you look at ISO9001 in the US it is labeled ANSI/ISO/ASQC Q9001-1994. Canada names it something different. But - they are 'equivalent' standards. So you can use either one as they are, name asides, the same.
Do note that in the QS series, QS is a customer requirement and their MSA (used as an example herein) requirements are beyond 45662A requirements so there is not a match there.
[This message has been edited by Marc Smith (edited 09-30-98).]
Old 8th October 1998, 10:54 AM
Iggy Gottesdiener
Unregistered Guest
Posts: n/a
Default
Maybe a very small point, but MIL-STD-45662 was "canceled" in February 1995, and inactive for new design after December 1994. The two "national" equivalents for calibration systems are ISO 10012-1 and ANSI/NCSL Z540-1. Unless you are running a calibration service, I'd recommend staying away from that one. You could also consider the NVLAP from NIST, which is based on ISO Guide 25. Again, that's really meant for cal service companies. IMHO, base your cal syatem on the ISO 10012-1.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Interpretation of "Plan and define the program" (sec.1, APQP Manual) morteza APQP and PPAP 3 28th December 2008 08:42 PM
Job Descriptions - Using "or equivalent" - ISO9001 ScottK ISO 9001 - Quality Management Systems Standard 4 3rd August 2006 09:13 AM
Old "outdated?" standards - Seeking an ASE J964 "grind lead test method" Jim Biz Other ISO and International Standards and European Regulations 6 9th January 2006 01:15 PM
Control Chart Interpretation - General "Rules" Jim Wynne SPC Monitoring and Statistical Analysis Techniques 18 21st October 2005 11:28 AM
Interpretation of the term "SAFEGUARDED" - ISO9001:2000 Clause 7.6 (d) MichaelWah ISO 9001 - Quality Management Systems Standard 7 1st September 2004 10:56 AM
The time now is 08:26 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
