Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > The Reading Room > Registered Visitor Articles Archive
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 10th June 2004, 03:17 PM
Jim Howe Jim Howe is offline
E-Mails Invalid or Rejected
Registration Date: Jun 2004
Karma Power: 0
Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.
Lightbulb Finding a Radius - How to measure diameters that are not a full diameter
The attached article was developed to solve a problem that befuddled us for a while. how to measure diameters that were not a full diameter. I would be very interested in your reviews.
Jim
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Sponsored Links
Old 10th June 2004, 03:54 PM
Steve Prevette's Avatar
Steve Prevette Steve Prevette is offline
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.Steve Prevette is appreciated, and has over 1700 Karma points.
Default
Seems to me you'd have a hard time determining the point of where the arc changes to a line so you can measure the distance across the arc. If it was me (and I actually have to do this on my model railroad's curves) I would cut out a template with the minimum (or maximum) allowable radius and lay that on the curved surface. Sort of a go-no go gage.
Also, taking practice from the railroads, the traditional way to lay out (or to check) a curve (where you can't find the center or don't have the full diameter) is to take a 100 foot chord (or otherwise fixed distance), lay it across the curve, and then measure the angle between the chord and the tangent to the circle.
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
Sponsored Links
Old 10th June 2004, 05:42 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
A resourceful way to solve a challenging situation.
Are there instruments designed to do this? I know I have seen instruments for measuring the radius of a sphere - a "tripod" that rests on the surface and a "micrometer" type probe at the center to measure the distance to the surface. The equivalent for a circle would be basically what Steve mentioned for the railroads - take a "beam" of known length and set it onto the curve. Attach a probe to the beam and to the curve.
( I tried to do and ASCII art drawing to show what I was thinking, but the spaces kept disappearing, ruining the picture. You'll just have to use your imaginations!)
If it doesn't exist, I sure think it would be a good item for someone to manufacture! This can't be the only shop that needs to do such measurements.
Tim F.
P.S. I like the "trial & error" spreadsheet approach for analyzing uncertainties. I could also solve the problem with calculus, but often the spreadsheet approach is just as quick and more intuitive. Calculus would have the advantage of giving a general equation that would work for different values of chord & height.
Old 10th June 2004, 08:01 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
Tim F.
For drawing (to hold the spaces) - use real characters rather than spaces, then change the color of the characters which should NOT appear to "white"
(done in magenta on top "V" and white on bottom "V" here to visualize)
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
Old 11th June 2004, 09:19 AM
Karma Power: 0
Default
Thanks Steve, actually when we first became befuddled we used the OEM steel pins that were made for the coupler. These pins usually ran about .008" to .010" under the diameter of the bore. Our task was to determine how much wear had occured in the radius area. Engineering set the criteria at .005% of the OEM pin diameter. By inserting the pin into the "hook" area we could tell that wear had occurred but not how much wear. The degree of wear determined if we could rework or if it was rejected as scrap.
I do like your idea of making up a set of radius gages and I intend to explore this more!
Again
Jim
Old 11th June 2004, 09:26 AM
Karma Power: 0
Default
Tim F.
Thanks Tim, I recently watched a demo of a CMM robot arm that could possibly do this in no time at all. the salesguy demonstrated that once set up touching the probe to 3 points on the curve would yield the radius. Cost was in Excess of $50000. My Engineering department is searching the cheaper versions.
PS. Although I studied calculus its been a few years ago. I felt more comfortable with the spreadsheet. Excel is great isn't it!
Jim
Old 11th June 2004, 09:27 AM
Al Dyer's Avatar
Al Dyer Al Dyer is offline
Mod...
Registration Date: Mar 2003
Thanks Given to Others: 4
Karma Power: 46
Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.
Send a message via AIM to Al Dyer
Default
Would the "cord" have any bearing?
Al...
"Para ... Bellum"
Old 11th June 2004, 09:47 AM
Jonell Jonell is offline
Involved - Posts
Registration Date: Apr 2003
Karma Power: 30
Jonell has less than 100 Karma points so far.
Default
Our industry here is metal stamping, so I don't know if this will apply to you or not. Do you have an optical comparator available? That is my preferred method of measuring a radius. I have radius charts that I can lay over the image on the comparator, works pretty well. Personally, I prefer NOT to use a CMM for this type of measurement, it is too dependent upon the CMM operator touching on the radius and not getting too far up the side into the straight edge.
All the best!
Jonell
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to Measure a Diameter - Average or Maximum/Minimum? dna_leri Inspection and Test, Sampling and Related Topics 25 16th September 2008 07:37 PM
Question on measure used for Gage R&R - Characteristic is a Knurled diameter JRKH Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 29th November 2006 10:04 AM
Cost Estimate for how many hours to measure a part (Full first artcle) Pat McGhie Inspection and Test, Sampling and Related Topics 2 15th March 2006 10:56 AM
Measuring Method - Inside diameter is off set from the outside diameter Jim Howe ISO 17025 - Calibration, Measurement Gages and Test Laboratories 11 7th September 2004 09:26 AM
Radius and Full Radius - Need a definition for each and difference(s) Proud Liberal Definitions, Acronyms, Abbreviations and Interpretations 5 12th February 2004 05:33 PM
The time now is 08:42 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
