When I visit R&D center,I found some software.this was used for verification of Design. This program is used for analysis of Base Foundation strength. Should this be calibrated or not.If so,where can I find the ISO clouse? I think this should be calibrated. But there is no detail description in ISO 9001.Only described for product related.
"The supplier shall ... control, calibrate, and maintain inspection, measuring and test equipment (including test software)..."
I had to address this for my Coordinate Measuring Machine to prove that the mathematical algorithms were correct. I just called the manufacturer and this is apparently standard practice.
I also noticed the the QS9000 PDF files available on http://Elsmar.com/pdf_files/ had a good section on Design (EOP-04-01, Sec 4 "Design Aids and Methods" which says:
"Computer software used for carrying out calculations and other design activities is qualified and approved". It goes on to say the various funky ways of qualifying and approving -- including getting a certificate from the s/w manufacturer.
