The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Quality Assurance Discussion Forums > Common Quality Assurance Processes and Tools > Documentation Control Systems, Procedures, Forms and Templates
Forum Username
Wooden Line
Preventive and Corrective Maintenance - Looking for a basic procedure
Monitor the Elsmar Forum
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering's
Quality Digest
LinkedIn Groups
ISO 9001 for Small Businesses
Information Security Community
Medical Devices Group
Quality and Regulatory Network
AS91XX Series - Tips and Advice
FDA (Food and Drugs)
Related Topic Tags
preventive maintenance, procedures (general)
Reply
  Post Number #1
Old 16th June 2004, 12:49 PM
Randy's Avatar
Randy
Please Help! Preventive and Corrective Maintenance - Looking for a basic procedure
I've bit off so much I am now starting to choke......
Does anyone have a generic (or one that can be changed) preventive maintenance procedure for production support equipment like banding machines, pallet jacks, material dollies, floor fans, and all that kind of stuff?
What I'm looking for is a basic procedure outlining how communication of maintenance needs can be handled, any supporting forms and so on, and the actual maintenance process itself.
I've stepped into a situation where there is no defined way to address how to tell the appropriate party that something is broke that has to be fixed.
Sponsored Links
  Post Number #2
Old 16th June 2004, 01:24 PM
ralphsulser's Avatar
ralphsulser
Randy,
I'll attach some forms we use, may help
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Thank You to ralphsulser for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 16th June 2004, 01:56 PM
Douglas E. Purdy's Avatar
Douglas E. Purdy
A General Flow
In Reply to Parent Post by Randy
Randy,
Here are two general flows for a process that did not have a Computerized Work Order & Scheduling System. If you want examples of forms, let me know. Hope this helps.
Doug
Thank You to Douglas E. Purdy for your informative Post and/or Attachment!
  Post Number #4
Old 16th June 2004, 03:03 PM
Wes Bucey's Avatar
Wes Bucey
Take a look at the kinds of things that Google finds when you enter:
"pallet jack" +maintenance
"fork truck" +safety
Also look at manufacturer websites to see what they offer in the way of handouts, procedures, checklists, etc.
Once you have some of these in hand, you might consider a top level safety procedure which says (even in flow chart form):
We want our operators to be safe when they operate any of the equipment in our plant. The best way to insure your safety is to know
  1. how to operate your equipment,
  2. how to check to ensure it is in proper condition for operation, and
  3. how to perform simple preventive maintenance procedures to keep it in safe running condition.
  4. what to do when the equipment needs repair
Then issue a checklist (laminated cover?) specific to the equipment that stays with each piece of equipment, similar to what pilots do prior to takeoff.
  Post Number #5
Old 16th June 2004, 03:41 PM
Randy's Avatar
Randy
Thanks so much...
What I ran across was a small piece of equipment that is used on a continual basis to help band material for shipment. The bander looks like a material dolly (2 wheels, a handle and all that), and 1 of the wheels was missing causing the employees to drag it from place to place. When I asked a supervisor why this thing hadn't been fixed (3-4 month old problem) I got the old "I told everyone so it's not my problem/responsibility" routine. Apparently there is no organized (formalized) process for requesting basic and performing maintenance/repair on infrastructure and support equipment (catch as catch can maintenance). No documents, no procedures, no records, NADA!
How to fix an item isn't the issue....how to get it fixed and to prove that we did so is.
  Post Number #6
Old 16th June 2004, 07:29 PM
Wes Bucey's Avatar
Wes Bucey
Thanks so much...
If the strapping (the preferred term over "banding") is steel - odds are the machine came from Signode or Uline - both companies have excellent PR for stuff like you need.
Google search would probably be (strapping + steel) or (strapping +plastic) using "strapping" will eliminate the hits for those steel bands that play island music.
  Post Number #7
Old 16th June 2004, 11:06 PM
Randy's Avatar
Randy
The strapping isn't a problem and the equipment isn't a problem, getting the stupid thing on 2 wheels is the issue....I found a dozen replacement wheels in less than 15 minutes at a Home Depot and another 6 or so at a nearby Ace Hardware....the issue is a guidance document that says "when junk breaks, here's what you must do to get it fixed"...
I was hoping someone had a down and dirty, basic procedure.
  Post Number #8
Old 17th June 2004, 09:46 AM
C Emmons
I dont know if this is the type of information you are looking for, but. If we have equipment needing repair, anyone has the ability to place an out of service tag, write it up (usually we use a standard vehicle inspection report for tractors, trailers, forklifts etc. Once the equipment is tagged out of service it is placed in a designated area and the report sent to mainteance. If we consistently end up with lots of equipment needing repair and it is impacting peoples ability to do their jobs, a formal corrective action is issued to managment.
Thanks to C Emmons for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Is a Procedure required for Corrective, Preventive, and Non Conformities Javiddemexico ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 9 14th November 2013 09:07 AM
Nonconformance, Corrective and Preventive Action Procedure(s)? CATERAF ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 12 7th August 2012 08:47 AM
Preventive Tool Maintenance - Preventive and Predictive Maintenance requirements try2makeit Manufacturing and Related Processes 7 16th November 2011 01:52 PM
Preventive Maintenance - Does anyone have a sample of a PM procedure? Hoeyster Documentation Control Systems, Procedures, Forms and Templates 5 3rd February 2006 12:58 PM
Corrective and Preventive Action - One Procedure or Two? Jimmy Olson Documentation Control Systems, Procedures, Forms and Templates 20 13th October 2004 01:19 PM
The time now is 07:04 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
