18th June 2004, 10:45 AM
Involved - Posts
Registration Date: Feb 2004
Karma Power: 32
Need to reference forms and ensuing records?
Within our procedures, I included a section for document references. There, we list the forms and any other procedures (document number and title) that are relevant and are mentioned within the procedure.
When a referenced form is filled out, it becoms a record. (Albeit not all records necessarily start out as ‘blank’ forms.)
Now then, is it necessary to also reference, within the procedure, the records that result from the referenced forms when these are filled out?
Thanks!
Alex
Additional information:
1) Our Master Record List includes the following fields or columns:
- Index No.
- Reference (whether it is a completed form or other type of record)
- Title
- Retention time
- Controlled by (department of function)
- Archival location ( – where: PC drive, file cabinet, drawer, etc.)
- The procedure(s) where the record is mentioned (such as: records are kept…)
2) Our Master Document List includes the following fields or columns:
- Index No.
- Document No.
- The procedure(s), if any, where the document is referenced
- Title
- Author (person)
- Responsible or used by (department of function)
- Revision No.
- Revision Date
- Topic or Description (very short)
- Archival location for original or master (.doc or .xls format)
- Archival location for public access in .pdf format
18th June 2004, 10:53 AM
When in doubt - THINK!
Registration Date: Jan 2002
Thanks Given to Others: 113
Karma Power: 217
Good question! Necessary? I don't believe it is.
However, my organization does do this. Within each document (excluding Forms) is a section called Documents Generated. It lists the document title, responsibility (basically, everyone who has an involvement in the generation of the document/record) and department (every department who has an involved in the generation of the document/record).
~ Roxane ~
"There's a fine line between genius and insanity. I have erased this line." - Oscar Levant
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
I believe the information in the thread Forms have no linkage to procedures or instructions - How to address? could be of use here?
/Claes
18th June 2004, 10:59 AM
Involved - Posts
Registration Date: Aug 2003
Karma Power: 50
Our blank forms are listed in the individual procedure and the document overview. They are controlled by our Control of Documents procedure (not all become records). If they become records that are retained for any reason, they are identified in and controlled as defined in our Control of Records procedure.
Mshell
18th June 2004, 11:01 AM
Courtesy Access
Registration Date: Nov 2003
Karma Power: 46
Hey Ingeniero1,
Just a casual suggestion. . . instead of listing the retention period on each document, reference your Control of Quality Records procedure. You may have changes over time in retention times, by referenceing the procedure, if a change does occur, you will only have one document to change. Granted the changes will have to be broadcast so that synergy of operation is maintained, but you will only have to discuss the procedure (or referenced Record Retention List).
Maybe you do this. . . and I may have missed something here
If something is over engineered. . . it will probably be under manufactured! (Jim Eustace 1993)
18th June 2004, 11:41 AM
Involved - Posts
Karma Power: 32
Given the above...
I believe I will keep it simple and just reference the form(s) that when filled out may be retained and become record(s). These records then will be controlled per our Records Control Procedure, which includes listing of these records in the Master Records list with all appropriate attributes. BTW, our Records Control Procedure states that records will be kept according to the retention time specified by the List.
Thanks!
ALex
18th June 2004, 11:54 AM
Registration Date: Jun 2004
Karma Power: 24 Karma: 67
Record Tracking via Database
I have a Form and document database. My control of quality records procedure references the database for document retention times. I also have Hyperlinks setup from the Procedure or work instruction where the form is referenced that will open up the form when excecuted. I think it is basically understood that all forms ultimatly become quality records. I also treat and reference all of my databases as quality records.
Hope this helps,
MNoah
Reason: Screwed up wording
