Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
17th March 2011, 04:12 AM
Appreciated Member
Registration Date: Jun 2002
Thanks Given to Others: 293
Karma Power: 150
Re: Flow charts - Show Me Yours! Systems Approach - Process Mapping
Marc,
Here is a deployment flowchart for the project to develop your process-based management system.
Examples of the core process (needs to cash) flowchart and flowcharted procedures will follow.
John
John R. Broomfield
Thanks to John Broomfield for your informative Post and/or Attachment!
17th March 2011, 05:32 AM
Appreciated Member
Karma Power: 150
Marc,
Here is a core process flowchart.
Note how it determines the key processes and shows their sequence and interaction.
The core process flowchart usually starts with determine customer needs and ends with invoicing; but here the filthy lucre is not mentioned (however the system from our eLearning course includes a key process for obtaining prompt payment starting with credit checks).
Key processes are those processes that benefit the organization by being documented for effective planning, operation, monitoring, control and improvement.
A key process flowchart used as a documented procedure will follow.
John
John R. Broomfield
17th March 2011, 05:38 AM
Appreciated Member
Karma Power: 150
Marc,
Here is a flowcharted procedure.
It shows the interaction of the resources that update the Business Management System as laws, codes and regulations are issued and changed.
The software is Teamflow which is designed for process and project management.
Our clients find it much faster to use and update than the general purpose Visio.
John
John R. Broomfield
17th March 2011, 09:00 AM
Technical Rep.
Registration Date: May 2009
Thanks Given to Others: 135
Karma Power: 33
Great post, I am a fan of flow charts.
The one I have included should be read from left to right then down to the next step. Or just go down to the process step concerned with and read left to right. This format speaks well to me.
Sorry, but it's in French. I have translated the top cells so you can get the drift of how it works.
Merci !
Tamale
There are those for whom the ability to speak only comes from their inability to shut-up! - Cyrano de Bergerac
22nd August 2011, 05:13 PM
Shy Poster (1 to 5 Posts)
Registration Date: Aug 2011
Karma Power: 8 Karma: 10
My first reply...
Impressed by all I have seen; I add a couple of my own points:a process must describe a domain-specific sequence
of course it must have inputs, methods and outputs
it must address process (functional) logic as well as governance (decision-points) logic
it must be auto-convergent, i.e. it should contain feedback (and even feed-forward) logic, so that the process logically drives the user to the intended purpose (terminal outcome)
In the end, most processes need to link up with some other (external) process to fulfil business continuity, and these "off-links" must also be shown
Forum Posting Settings
