Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > The Reading Room > Registered Visitor Articles Archive
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 3.00 average. Display Modes
Old 7th July 2004, 02:38 PM
Jim Howe Jim Howe is offline
E-Mails Invalid or Rejected
Registration Date: Jun 2004
Karma Power: 0
Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.
Default Dimensional Layout Errors
Since reading some of the fine articles being submitted I decided to really bore the readers with one more article on measuring?
This article was written for my own benefit when I was suddenly assigned to perform reverse engineering layouts. You understand, I am sure, that its one thing to perform dimensional layout when you have a drawing in front of you and you know what the dimension should be. It is quite another when you have no drawing and no clue what it should be.
To reconsile the logic in my "brainbox" and minimise errors the article was written. I warn you it is quite boring!
Jim Howe
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Sponsored Links
Old 14th July 2004, 03:46 PM
Karma Power: 0
Default
I want to attempt to remove the article from theory and show a practical application. Please view attached photo and note that we would be measuring the distance between the two bores in both the x, y and z axis. (red arrow represents the z-axis)
Sponsored Links
Old 14th July 2004, 05:36 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Jim,
Thanks for submitting an article. OK, I'll agree with you that it isn't the hippest topic in Quality, but it was well-writen and useful for those looking to measure offsets of holes.
A couple more specific notes...
( Stop reading now if you don't want to have the plot spoiled )
1) If you just used the names "high pin" and "low pin" instead of "Pin 1" & "Pin 2", you could simplify the two rules on the top of page 3 to a single rule something like "The center to center distance is the surface to surface distance PLUS the radius of the lower pin MINUS the radius of the higher pin."
It makes one rule to remember instead of 2.
2) I think you are slightly overestimating the potential error due to being off-center. Consider the example you give of the measuring instrument being up to 10 degrees off-center from the top of the pin, with the larger pin higher. Look at four cases:
  1. Both measurements are 0 degrees off. This gives the true center-to-center distance (CC).
  2. The larger pin is 10 degrees off. This will decrease the measured CC by the 0.015 you calculated.
  3. The smaller pin is 10 degrees off. This will increase the measured CC by 0.030.
  4. Both are off. This will increase the CC by +0.030-0.015 = 0.015.
The worst you can be off is the error caused by the smaller pin. The addition of an error in the larger pin will actually decrease the overall error in CC! This would be true for whichever pin is higher.
Or think about two identical sized holes. If the measuring instrument is off-center the same amount for both, you will still get the right answer! You don't have to add the errors for each.
Tim F
Old 15th July 2004, 08:22 AM
Karma Power: 0
Default
Tim, thank you for the insight! I will take a closer look but I think you are correct.
Old 22nd July 2004, 02:46 PM
Karma Power: 0
Default
Tims comment about using high pin & low pin proved to be a catalyst. I have revamped the article as a result. Thanks Tim.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Layout and Dimensional Inspection Training Satellite Training - Internal, External and Distance Learning 0 4th April 2007 09:35 AM
Layout inspection - When is a layout inspection required? andre-soares Inspection and Test, Sampling and Related Topics 4 15th September 2005 08:19 AM
FAQ - MySQL errors Marc Old Forum News and Issues Threads Archive 2 24th February 2005 04:10 AM
8.2.4.1 Layout inspection - When is a full layout required and how often? Ayelet Inspection and Test, Sampling and Related Topics 8 23rd February 2005 03:50 PM
The time now is 08:47 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
