Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th July 2004, 02:57 PM
Connie Connie is offline
Registration Date: Jan 2003
Karma Power: 28
Connie has less than 100 Karma points so far.
Question Blind, Threaded Hole - How can I Eliminate Chips?
Hi Everyone It's Been A Long Time But We Have Been Very Busy.
I Have A Question (not Sure Where To Post It Though) About A Part That Has Been Driving Us Nuts For Quite Some Time, So Any Help Will Be Greatly Appretiated!!!!
Here It Is:
We Make A Few Parts That Have A Blind Threaded Hole, Our Customer Tells Us That They Cannot Have Any Debris Or Chips In The Holes, Now We Have Tried Everything We Can Possibly Think Of To Eliminate This Issue, We Used Chip Breaking Tools Which Have Helped Some To Eliminate The Larger Chips, We Have Put Parts Immediatly In Solvent To Release Any Oils That May Be Making The Chips Hang In There, We Have Tried Vibration Washing None Of Which Eliminates This 100% Which Is What The Customer Wants.
These Are Run On A Five Spindle Davenport Screw Machine.
If Anyone Else Runs This Type Of Part And Has Been Successful At Eliminating The Chips Please Let Me Know How You Do It!!!
Thannk-you!!!!
Connie
Also Where Is The Spell Check???
Sponsored Links
Old 7th July 2004, 03:33 PM
Mike S. Mike S. is offline
An Early 'Cover'
Registration Date: Mar 2002
Thanks Given to Others: 24
Karma Power: 103
Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.
Default
Maybe high pressure air or water sprayed into the hole???
By the way -- are you stuck on title case by accident?
Mike S. ("Gun Nut")
And they ask me why I drink....
Sponsored Links
Old 7th July 2004, 03:36 PM
mshell's Avatar
mshell mshell is offline
Involved - Posts
Registration Date: Aug 2003
Karma Power: 50
mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.mshell is appreciated, and has over 700 Karma points.
Default
Connie,
I would suggest that you conduct a root cause analysis of the problem, determine what is causing the nonconformance, identify potential solutions and implement the most effective solution.
Mshell
Old 7th July 2004, 03:51 PM
Karma Power: 28
Default
No I just always have my computer on caps lock because I do all my inspections sheets in caps because they are almost all dimensions with the exception of a few commands. Sorry!!
Getting back to the problem at hand, we have been using the air pressure but what I want to get away from is handling each part individually. We run millions of these.
And I really have not tried to do a root analysis, since we know how the chips are getting there would it really help?
Please keep thinking any suggestions will be looked into.
Thanks for your fast responses!!!
Old 7th July 2004, 03:53 PM
mshell's Avatar
Involved - Posts
Karma Power: 50
Default
Is there something that can be done to eliminate the root cause without compromising the process?
Mshell
Old 7th July 2004, 03:58 PM
An Early 'Cover'
Karma Power: 103
Default
Are the holes bored? If so, maybe high vacuum applied while boring?
Must it be a blind hole?
Mike S. ("Gun Nut")
Karma Power: 28
Default
That is what I'm am trying to find out if there is any type of wonder equipment or tooling or even a new type of washing equipment that has worked sucessfully for someone else.
Old 7th July 2004, 04:03 PM
Karma Power: 28
Default
We have just spoken to another machinist (lots of experience) he suggested we hook a high pressure air hose inside the machine to shoot a burst of air into the hole immediatly befor it drops into the catch container.
I'll let you know how/if it works.
Keep the thoughts coming this may not work.
Appriciate all your inputs!!!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Problems with a counter bore & the I.D. hole - .0685mm to .0762mm I.D. hole Brad Eickhoff Manufacturing and Related Processes 9 1st April 2008 02:24 PM
File Attachments in PM (Private/Personal Message) or Forum 'Blind' Email Bill Ryan Instructions --> How to use the Forum Software 1 14th February 2007 08:45 AM
U. S. Passport Security (RFID chips) Wes Bucey General News and Business Articles 17 7th November 2005 01:26 PM
Strategies for Going In Blind - My employer is probably confused why I'm here David Mullins Misc. Quality Assurance and Business Systems Related Topics 11 1st May 2002 11:02 PM
Threaded Views: Last First or First Last Marc Old Forum News and Issues Threads Archive 5 1st September 2001 12:02 PM
The time now is 06:09 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
