Go Back   The Elsmar Cove Forum > National and International Business Standards > Various Other Specifications, Standards, and related Requirements
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th July 2004, 01:53 PM
qualitygoddess's Avatar
qualitygoddess qualitygoddess is offline
Involved in Discussions
Registration Date: Jul 2004
Thanks Given to Others: 12
Karma Power: 42
qualitygoddess is appreciated, and has over 500 Karma points.qualitygoddess is appreciated, and has over 500 Karma points.qualitygoddess is appreciated, and has over 500 Karma points.qualitygoddess is appreciated, and has over 500 Karma points.qualitygoddess is appreciated, and has over 500 Karma points.qualitygoddess is appreciated, and has over 500 Karma points.
Please Help! Working with UL for Product Certification - Electronic component
Just starting to research the recognized component mark from UL. The company I am with wants to obtain this for a electronic component. Anyone have any words of wisdom for dealing with UL??
--Jodi
Sponsored Links
Old 13th July 2004, 02:09 PM
ralphsulser's Avatar
ralphsulser ralphsulser is offline
Quality Team
Registration Date: Jun 2002
Thanks Given to Others: 87
Karma Power: 127
ralphsulser is appreciated, and has over 1700 Karma points.
ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.ralphsulser is appreciated, and has over 1700 Karma points.
Default
I worked with UL several years ago regarding UL labeling of rubber and plastics products and never had a problem with them. Just make sure you are d oing the right things
"Nothing is constant except change"
Sponsored Links
Old 13th July 2004, 02:23 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
--Jodi
I've worked for UL and I now use ETL (Intertek) for safety testing. I believe UL will give you a more detailed report and include the raw data. I would look at both for your requirements since either one can issue a mark that is recognized in the US, Canada and around the world. Also look at CSA. They may differ in delivery time and cost.
Al
Old 14th July 2004, 09:56 AM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
One thing to keep in mind when dealing with any of the product certifiers (UL, CSA, Intertek, ARL, etc.) is to clearly define the requirements including the markets and by extension the likely customer base, and the projected use of the component and in what environment(s).
Each of these organizations has many test standards available and which ones will be used depend on the client giving good information. Each of these organizations does a good contract review, but still depend on the client.
I can assure you that each of the organizations named in this thread so far are good and are reliable. Each carry mutiple acreditations (including IAS).
Hershal
Old 14th July 2004, 05:08 PM
mitsu11 mitsu11 is offline
Registration Date: May 2004
Karma Power: 23
mitsu11 has less than 100 Karma points so far.
Default
My suggestion for dealing with UL is to get well acquainted with the product standard before you even call them. Most of the time, you can walk in and tell them what you feel is needed for testing, and save a bunch of time and headaches. Also by doing this, you (should) have done your pre-testing to ensure the product will pass their test.
Your engineer will become your best friend for a while, so make sure there is a good rapport. After the project is done, the engineer will step out, and the follow-up services inspector will step in. This is also a very key relationship to maintain.
There are some different rules between UL listed and UL recognized, too, so do your homework there. In general, get to know the organization as a whole, perhaps even volunteering for the Standards Technical Panel (STP) for the standard you will be using.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Electronic Quality Manual - Does anyone have working Electronic Quality Manual? Maija ISO 10013 - Quality Management System (QMS) Manuals 25 11th April 2009 07:33 AM
Component Traceability for a Class 2 Electronic Medical Device Le Chiffre ISO 13485 - Medical Devices - Quality Management Systems 1 12th July 2007 01:27 PM
Does ISO 14001 certification enhance environmental performance? - A Working Paper Sidney Vianna ISO 14001 and Environmental Related Standards 3 28th May 2007 02:06 PM
Product audit finding? Traceability of a component from a purchased assembly Quality-Misfit ISO 19011 and ALL Auditing Discussions 3 20th February 2007 10:01 AM
Process FMEA Applicability for an Electronic Component raghuraman FMEA and Control Plans 2 11th June 2001 12:32 PM
The time now is 10:59 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
