Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Process Maps, Process Mapping and Turtle Diagrams
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 26th July 2004, 04:32 PM
Jonell Jonell is offline
Involved - Posts
Registration Date: Apr 2003
Karma Power: 30
Jonell has less than 100 Karma points so far.
Question Should "process maps" be challenged? Does TS 16949 require process maps or not?
Hello all,
It seems that I have heard over and over that TS does NOT require you to map your processes. However, I just submitted the quality manual to our registrar. Below is the comment that came back on process maps:
"TS 16949-2002, clause 4.2.2.c – the diagram submitted DOES NOT address the information requirements for the TS 16949-2002 automotive approach.
Please submit the (company name) Process Maps referenced on the diagram.
Make sure that they are part of the quality manual."
Ok, if TS doesn't REQUIRE you to map your processes, then how come some registrars are demanding it, right down to what format you are supposed to use? (turtle diagram is required in this instance)
Jonell
Sponsored Links
Old 26th July 2004, 06:35 PM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
The ONLY requirement is to define each process and then describe the interaction between them. Nothing more, nothing less.
Although process mapping/process diagrams is/are not required, it may be the easiest and the best pictorial method. Next would be a tabular method, which by the way, is the method defined by AIAG for the automotive approach. And it also follows the control plan approach. You could also prepare a written description; however this might become a little confusing.
"TS 16949-2002, clause 4.2.2.c – the diagram submitted DOES NOT address the information requirements for the TS 16949-2002 automotive approach."
Did your auditor explain what these "information Requirements" are? It would be interesting to hear what he would say.
Sam Goody
Sponsored Links
Old 26th July 2004, 09:46 PM
WALLACE's Avatar
WALLACE WALLACE is offline
Courtesy Access
Registration Date: Nov 2000
Karma Power: 67
WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.
Send a message via Skype™ to WALLACE
Default
Jonell,
If you submit flowcharts as being an integral part of your BMS, expect them to be assessed by a third party auditor.
Regardless of the inclusion, requirement or not by ISO/TS. If you even include a cartoon in your QM, it shall be assessed by a third party auditor for conformity to the standard and your good old fashioned planned arrangements.
Wallace.
Ask, Seek, Knock.
Old 27th July 2004, 08:17 AM
Involved - Posts
Karma Power: 30
Default
Sam,
I'm assuming that he considers the information requirements to be the process maps. He goes on to give me a list of what is required to be included in the process maps.
Jonell
Old 27th July 2004, 10:47 AM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Default
Originally Posted by Jonell
Sam,
Jonell
Could you share with us what other requirements your auditor is says should be included.
The only requirement of para 4.2.2.c is to describe the "interaction" of the processes. Have you done that? I don't believe your auditor can tell you how your processes sould interact.
Wallace is correct. If you have submited process maps they will be reviewed. However this does not mean there is to be additional requirements.
As I read further in your first post, I see the mention of the turtle diagram. This is an aid to help in determining if your process meets the requirements for an automotive process, i.e, inputs, activities, outputs. It is not a requirement to include these with the quality manual.
Refer to the Errata sheet to the Quality System Assessment Checklist for additional information. This can be found on the AIAG website.
Sam Goody
Old 27th July 2004, 10:57 AM
Sean Kelley's Avatar
Sean Kelley Sean Kelley is offline
Involved - Posts
Registration Date: May 2003
Thanks Given to Others: 25
Karma Power: 32
Sean Kelley is appreciated, and has over 100 Karma points.Sean Kelley is appreciated, and has over 100 Karma points.
Default
We just passed our TS2 Registration audit and were the first to do so with zero nonconformances. I can tell you our auditor also looks at effectiveness and efficiency of your processes. So just having the process maps will not solve the issue of what your results are. If you have good results then they will be less critical of how you are doing something.
MILO2000
Old 27th July 2004, 11:50 AM
Involved - Posts
Karma Power: 30
Default
Sam,
I'd be happy to. According to the auditor, the process maps are to be included as part of the quality manual. Below is what he sent:
"Please submit the (company name) Process Maps referenced on the diagram.
Make sure that each process map addresses and documents the following:
For each documented process, ask and answer the following criteria:
1) What is the internal/external customer-required output?
2) What activity(s) are performed to produce the output?
3) What equipment, material, environmental needs, etc. are needed to do this?
4) What personnel(which job functions), skills, experience, special knowledge are needed to do this?
5) What procedures, specifications, forms etc., are used to produce output?
6) How is the process measured for effectiveness in producing output that meets or exceeds the customer’s need? Each COP requires a measurement indicator, as an absolute minimum.
7) What other processes provide inputs, or use the output produced from this process? (i.e., linked processes)
8) What other processes need to be in place and functioning adequately to allow this process to function correctly to produce the required output(s)? (i.e., supporting processes)"
I have the process maps done, and will submit them to him as part of the quality manual, so that he is satisfied. They are done in the turtle diagram format, because that is the way he wants, that is the template that he gave me to use when he was here for the pre-assessment.
Jonell
Old 27th July 2004, 09:57 PM
Valeri's Avatar
Valeri Valeri is offline
$ Contributor
Registration Date: Nov 2002
Thanks Given to Others: 58
Karma Power: 55
Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.Valeri is appreciated, and has over 900 Karma points.
Default
IMO you need to find a new registrar or maybe it's just the auditor. Sounds like this one expects you to perform the audit for him and is using the old "QS-9000" tactics/methods to audit. Personally, I would have serious issues with this auditor.
Attached is the quality manual process map we used to certify 9 manufacturing sites to the TS standard (some references have been deleted to protect the innocent ). All plants received certification without one nonconformance sited.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ISO/TS 16949 "Certification" & "Product and Process Design" Clauses YHHTT ISO/TS 16949 - International Automotive Quality Systems Standard 5 1st November 2009 05:08 PM
Are Process Maps Mandatory (Required)? TS 16949 jrubio Process Maps, Process Mapping and Turtle Diagrams 11 27th August 2006 12:57 PM
Process Maps - I made my mind up - We do not need maps ISOPete Process Maps, Process Mapping and Turtle Diagrams 4 7th December 2004 05:55 PM
Does ISO 9001:2000 Specifically Require Process Maps? CarolX Process Maps, Process Mapping and Turtle Diagrams 19 19th June 2004 05:50 PM
Process Mapping - Is there anyone using process maps to meet 4.1 requirements? VICAHUNT Process Maps, Process Mapping and Turtle Diagrams 3 4th September 2003 08:23 AM
The time now is 03:22 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
