30th July 2004, 08:41 AM
Involved - Posts
Registration Date: Feb 2004
Karma Power: 32
Temporary Bandit, Ad Hoc or Rogue Records, Forms, Data, Documents - How to Justify
We have been searching for what we consider 'bandit' documents and records; i.e., those that are uncontrolled, have no number, version, approval, etc., and are just laying around or pinned up on a wall. When found, we either destroy them (usually not needed anyway), or we add the necessary notations and archive appropriately.
We have found a few, however, that are not so clear cut: Blank sheets of paper where operators jot down information so they can later enter said information in the appropriate computer screen (database) or perhaps write it down on a controlled form to become a bona fide record. The hand-written sheet is thrown away after the information is 'transferred', which normally is done within a few hours.
I thought about generating forms (properly annotated and controlled) for the operators to jot down the information. However, these filled forms (now records) would still not constitute an actual controlled record as they are discarded.
Could these temporary, uncontrolled records be a problem, or would it be OK to allow the practice to continue as is?
Thanks -
Alex
30th July 2004, 08:59 AM
E-Mails Invalid or Rejected
Registration Date: Oct 2003
Karma Power: 0 Karma: 61
I would have thought that you are OK with what you are doing providing you have the following in place.
1) A document number assigned to the form the operators are completing, to provide a reference for the operator to request.
2) You have a procedure / flow in place covering the notation of records manually at lineside (refering to the document in point 1) through to updating records online.
If you feel and can demonstrate the effectiveness of the system you have, and convince the auditing body of this you'd be unlucky to be penalised on this one.
If it ain't broke don't fix it.
30th July 2004, 09:17 AM
$ Contributor
Registration Date: Aug 2002
Thanks Given to Others: 6
Karma Power: 47
We actually have a little bit of both in our lab. We use a home made LIMS to enter/report/store all of the data we generate. Some of the tests we do require the techs to write raw data down on a sheet of paper, which is alway a form of some kind. The raw data is then entered to the LIMS and the paper form is discarded. Most of the paper forms we use are NOT controlled forms, but a few are. We are looking to get all of the data forms out of the QMS and make them uncontrolled, since we only temporarily use them and then toss them. We've never had an issue with this in our 3rd party audits, because we never wrote ourselves into a corner over it. Ifyou are not forcing yourself to control them in your own QMS, then the standard does not force you to either, in this particular instance.
Joe Cruse
30th July 2004, 09:29 AM
Registration Date: May 2003
Thanks Given to Others: 389
Karma Power: 128
Originally Posted by Ingeniero1
...Blank sheets of paper where operators jot down information so they can later enter said information in the appropriate computer screen (database) or perhaps write it down on a controlled form to become a bona fide record. The hand-written sheet is thrown away after the information is 'transferred', which normally is done within a few hours...
I'd have a real problem around here if I told people they had to use a controlled document instead of a scratch pad.
First thing each morning, I try on my bathing suit. Then, nothing worse can happen the rest of the day.
30th July 2004, 09:30 AM
$ Contributor
Registration Date: Sep 2000
Karma Power: 63
Make a form part of the work process description
I am in a calibaration environment, so this may not work for you the same way it does for me ...
If a calibration procedure requires the technician to record temporary values or intermediate calculations, then an appendix to the procedure contains forms for that purpose. When final measurement results are recorded, either directly by the automated procedure, or in the laboratory database, or on a form that is also part of the procedure (but in section 5, not an appendix).
If the work process has a written instruction, then it may also be possible to do the same thing - put a simple form for recording temporary values and calculations in the process instruction. Include a note that it can be reproduced as needed and destroyed after use. If it is part of the instructions for the work process then the issue of controlling a separate form vanishes.
Graeme C. Payne
ASQ Sr. Member; CQE; CCT
"Does it matter if the measurement result is wrong?
If it does, then calibrate the instrument.
If it doesn't matter, they why are you making the measurement?"
(P. G. Stein, 2000)
30th July 2004, 10:29 AM
Courtesy Access
Registration Date: Feb 2003
Karma Power: 66
Thanks -
Alex
Alex,
If you have not had problems with personnel making errors in this transfer process, why complicate the process with worthless "controlled" forms?
There are many times during a day that I (and most of the world around me) jot down a few notes, either to remind us of things to do, people to meet with, all of which may be directly related to my work - but I do not need, nor am I required to take these notes on "controlled" forms.
Don't make your quality system so cumbersome that it doesn't make sense, and is a setup for failure (people are always going to jot things down and in many cases that is a good thing, why force them into having to search for a specific controlled form in which to accomplish this - Afterall they may need a form to jot down where the controlled forms are being maintained.
David D. Hartman
30th July 2004, 11:07 AM
Involved - Posts
Karma Power: 32
Cari -
You bet - ditto here!
David -
Amen to that!
I'll keep it simple, as it is now, and be done with this issue. (KISS principle rears its 'pretty' head again!)
Thanks,
Alex
30th July 2004, 04:35 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
I used to address these in a 'procedure' and called them 'Ad Hoc' documents. The procedure detailed how to put uncontrolled documents on the floor. In fact, I did this so long ago it was part of my original site in 1995-96. Back then a link to the gif picture of a mountain range below was on the header of every page (as it still is on http://Elsmar.com/iso9000.html - Click the Mountain range on that page).
Look at Level 5...
This also addresses bulletin boards and related - well, 'ad hoc' or 'rogue' documents.
Minimum requirements:
Date issued/posted
Signature/Initial or other way to track the owner (responsibility)
Date of expiration
I was 'born' into 'quality' in a military manufacturing environment. I long ago learned you can do what you want if you can explain it and have - at a minimum - basic guidelines.
