Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 5th August 2004, 01:42 AM
nick1980 nick1980 is offline
Registered Visitor
Registration Date: Aug 2004
Karma Power: 22
nick1980 has less than 100 Karma points so far.
Please Help! How to determine Type-B uncertainty?What distribution?With Calibration beginner guide
I don't know how to determine the type-B uncertainty because it has many possibilities such as past experience, calibration certificate.
In type-B uncertainty, the formula is varied by different distribution of measurement values (normal, rectangular, triangular, etc.). How do I know what distribution I should use? Does it assume all measurements rectangular distribution with formula 0.5*limit/sq. root of 3?
Also, I found a very good guide for beginner about calibration. I share it to you all.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Sponsored Links
Old 5th August 2004, 04:03 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Hopefully, someone can answer the thread starter's original question.
Sponsored Links
Old 5th August 2004, 04:48 AM
Charmed Charmed is offline
Registration Date: Jul 2004
Karma Power: 24
Charmed has less than 100 Karma points so far.
Default Type B Uncertainty
Dear nick1980:
The following link takes you to a nice presentation by FLUKE on measurement uncertainties.
http://www.npl.co.uk/electromagnetic...sfer/fluke.pdf
See page 12, which I quote. Type B uncertainties are said to be 1 standard deviation estimates of the likely range of values the value may have (Often considered as systematic uncertainty). See also the following article by Dr. Stephen Phillips of NIST.
http://www.mel.nist.gov/proj/pdf/Mea...rtainCA34A.pdf
Charmed
Old 5th August 2004, 05:27 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Read This!
Nick,
Welcome to the Cove Forums!
I had asked a similar question in one of the threads here..It may help if you go through it:
http://elsmar.com/Forums/showthread.php?t=5689
I'm sure our calibration experts on board will chip in with more useful replies.
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Old 5th August 2004, 11:37 AM
Registered Visitor
Karma Power: 22
Thank You! 1 stand deviation=type-B uncertainty??
Thanks Charmed!!
From your reference, 1 stand deviation=type-B uncertainty. Can you tell me why?
It's because I found many different formula to calculate type-B uncertainty for normal, rectangular, triangular or uniform distribution.
If type-B is really equal to 1 s.d., that's so great.
It makes the calculation easier a lot.
Old 5th August 2004, 11:59 AM
Registered Visitor
Karma Power: 22
Default definition of standard uncertainty.
I found a definition of it:
standard uncertainty = one standard deviation.
But in order to minimize the possibility of mistakes at a later stage of the evaluation, it is sometimes necessary to multiply values of type-A estimated standard deviations and type-B standard deviations by suitable sensitivity coefficient to bring them to the same units as the measurand or to take account of other factoes in the funcitonal relationship between input quantities and output quantity.
So what standard uncertainty equals to ? one s.d.? or typeA+typeB uncertainties? (type-A estimated standard deviations = type-A uncertainty??same meaning?)
Old 5th August 2004, 06:11 PM
Karma Power: 24
Please read the article by Stephen Phillips which explains these things nicely, which I gave link to. I will check another source and get back to you.
Charmed
Old 5th August 2004, 08:18 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
Nick,
There are two answers going on here, and I will presume you are in a cal lab, not a test lab.
Standard uncertainty is one standard diviation, or approximately 67%. Expanded uncertainty is two standard diviations, or approximately 95%.
Type B uncertainty distribution model will vary depending on the influence. GENERALLY, the Type B is a normal distribution. GENERALLY, the Type A is rectangular, in that the true value can lie anywhere within the uncertainty range. These are rules of thumb, not hard and fast.
Type B can include the environmental concerns such as temp, RH, vibration, and dust. Recognize that the environmental influences might change. In some cases for example, temp and RH changes have no effect over a wide range. In the test lab world, that is common. Other effects include calibration uncertainty taken from the accredited calibration cert (plug and play number), time, viewing angles, technician proficiency, almost ANYTHING that can affect the measurement to a measurable degree.
Hope this helps.
Hershal
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to Determine Attribute Gage Uncertainty Coleman Donnelly Measurement Uncertainty (MU) 1 14th May 2008 05:23 PM
Relative or Combined Type A & Type B Uncertainty Calculation? amanbhai Measurement Uncertainty (MU) 4 12th December 2007 07:50 PM
MU - Type B estimation - Which distribution to use? Triangle? Rectangular? wcsf ISO 17025 - Calibration, Measurement Gages and Test Laboratories 3 6th May 2005 10:20 AM
How can I determine the kind of distribution - What about Bionimal or Poisson? vasilist SPC Monitoring and Statistical Analysis Techniques 3 28th August 2002 12:12 PM
Uncertainity & Student's T distribution - Calculus of uncertainty in calibration sergiop Measurement Uncertainty (MU) 1 9th August 2001 12:46 PM
The time now is 05:47 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
