Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 16th August 2004, 06:05 AM
Cartier Cartier is offline
Registration Date: Aug 2004
Karma Power: 22
Cartier has less than 100 Karma points so far.
I Say... Linking Acceptable Quality Levels (AQL) and Average Output Quality
I am currently working on the relation between AQLs and average quality output for the following reason:
AQLs for critical product defects (which render the product non-functional) are often defined at 0.15%, which corresponds to 15 parts per ten thousand. If you are talking about beer cans, if 15 leak every thousand that is a lot of cans leaking.
Suppliers usually say that if you define an AQL of 0.15%, the actual quality of the production is likely to be better than that percentage.
Would you agree with that statement?
If so, how do people link up actual quality output and average quality levels. My contact with suppliers has led me to believe that quite often they themselves do not fully understand the military standard 105.
My understanding is that if you define an AQL of 0.15% and you apply a normal sampling plan using military standard tables, as a buyer you only have a 10% chance that what you purchase is going to be outside of that acceptable quality level. That means there is a 90% chance that your purchase will be within that quality level, but then what is the chance that your quality will exceed that quality level.
On a standard OC curve (from http://iew3.technion.ac.il/sqconline/milstd.php3, aql 0.15%, II 35000-150000). I am interested if anyone knows how I can get a better picture of the probability between p=[0.0 0.0015].
Does anyone know about military standard history or where I can find out about how it was created. I am interested to know whether it was established through extensive testing by the military, or whether it stems from binomial distribution type mathematics.
Owen Cartier
Sponsored Links
Old 16th August 2004, 06:36 AM
Charmed Charmed is offline
Registration Date: Jul 2004
Karma Power: 24
Charmed has less than 100 Karma points so far.
Default Probability calculation, for low p values
Dear Cartier:
Here's my $0.01 worth.
You have, I am sure, heard about the normal, or Gaussian, distribution curve. If you test the lifetime of a light bulb, for example, the data, follows the normal distribution. If you test the lifetime of tires, again we will see a normal distribution! That's the marvel of mathematical logic.
We can take the area under the normal distribution curve as a measure of the probability of the occurrence of an event. For the standard normal curve (see textbooks), the total area under the curve is taken as 1. This area can now be divided into two parts. One part of the area is probability of success. Let's say it is 0.85. The probability of failiure, or producing defect, is the other part of the area. This is 1 - 0.85 = 0.15. I picked this because you were talking about 15% defects. Probability of success plus probability of failure equals 1.
Now, how do we find these areas? We make measurements. Let's call each such measurement X. We make a lot of measurements. We get an 'average' or the mean value. Let's call it M. (In statistics books, they call it mu, the Greek letter). Then, we can find the standard deviation. Let's call it S. (They call it sigma, another Greek letter.)
Now, we can go from X, which is called raw score, to what they call Z score. The Z-score is defined as Z = (X - M)/S.
There are tables which give the area under the normal curve, up to the desired Z value. The Z-values go from minus infinity to plus infinity. If Z = 0, X = M, the average value and so on both sides of the mean. Statistical packages (MINITAB) also make these calculations very easy. You can write your own program, using Microsoft Excel, which is what I would do for this purpose. (This also helps me avoid some approximations made in the calculations, commonly carried into statistical packages. This can be avoided now, since we have such awesome computing power in our hands now.)
Once, you get all your measurements, you refer to the tables and find the probability of being outside certain limits (converted to Z values). Hence, we calculate the area between Z = 0 to Z = USL, the Upper Specification Limit, converted to Z using the M and S values. You can also do the area calculations using the library of functions in Microsoft Excel.
You should be able to get actual worked examples in many standard statistics books. The example of lifetime of light bulbs, or tire life (e.g. to offer a warranty of exceeding a certain miles to the customer) is discussed in many books.
Hope this is helpful.
Charmed
P. S. If you have some numbers, please feel free to post them and let's do the calculations here.
Sponsored Links
Old 16th August 2004, 08:00 AM
Karma Power: 22
Default
Thanks for your feedback. I understand the normal distribution curve theory, but rather than using numbers to work out probabilities between 0 and 0.0015, I am more interested in the maths behind the actual acceptable quality level tables. Where does all this information come from.
For probabilities between 0 and 0.0015, I am trying to figure out if I set an AQL of 0.15%, what is the probability that my production will have an average output quality of 0.05%?? Is there a way to measure this? Why do suppliers often suggest that this is the case.
Old 16th August 2004, 05:56 PM
Govind's Avatar
Govind Govind is offline
Registration Date: Apr 2004
Thanks Given to Others: 13
Karma Power: 50
Govind has disabled his/her Karma.
Default
Cartier,
See attached.Here is my attempt to explain this by an example. I have made several assumptions due to lack of supporting specification.
Regards,
Govind.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 16th August 2004, 07:55 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is online now
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Cartier,
Two comments.
1) The relationship between AQL and risk is tenuous at best. I worked out the numbers once for a variety of AQL levels and lot sizes, an discovered that I couldn't find any specific criteron for how the accept/reject numbers were set. Typically, about 95% of the lots are excepted when a) the actual quality of the lot = AQL and b) the lot size is large. When the lot size is smaller, then the lot has to be considerably better than the AQL to be accepted 95% of the time (about 1/3 AQL).
In other words, there is no simple rule and you have to look at the OC curve if you really want to know the odds of accepting lots at any specific quality and for any specified MIL-STD-105E (ASQ Z1.4) sampling plan.
2) The average quality that you accept can only be determined if you know something about the quality coming in. Consider your plan with AQL = 0.15 (=0.15% defective). As an extreme example, suppose that every one of the incoming lots is exactly 0.5% defective. You will reject many of the lots, but you will also accept many of the lots. The quality of the accepted lots will, of course be 0.5% defective in this example, which is much worse that the 0.15% "acceptable" quality level!
Tim F
Old 6th October 2006, 09:09 AM
brutas brutas is offline
Involved - Posts
Registration Date: Sep 2004
Thanks Given to Others: 9
Karma Power: 23
brutas has less than 100 Karma points so far.
Send a message via ICQ to brutas
Default Re: Linking Acceptable Quality Levels (AQL) and Average Output Quality
Can anybody explain this to me?
I thought that AQL=0.15% means that your process produces 15 failed devices per 100 units.
Why per 10 000? There is something I am missing...
Old 6th October 2006, 09:15 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is online now
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
You're missing decimal places. 0.15 = 15%, but what's being referred to here is 0.15%. or 15-hundredths of 1%, or .0015.
Old 21st November 2006, 12:25 AM
thomastang thomastang is offline
Registration Date: Nov 2006
Karma Power: 13
thomastang has less than 100 Karma points so far.
Send a message via MSN to thomastang
from reveiw point of application of Sample Table, it abusolutely exist risk, so we call it "sample" checking.
if apply same AQL in your company and your supplier, whatever, they need agree it.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Problem with AQL (Acceptable Quality Level) damienbechaux AQL - Acceptable Quality Level 9 5th August 2009 07:04 PM
AQL - How do I find Acceptable Quality Level? qmslady AQL - Acceptable Quality Level 72 8th June 2009 05:07 PM
Acceptable Quality Levels (AQL) - What is the usage of AQL 100 to 1000? WLN AQL - Acceptable Quality Level 10 18th July 2008 07:58 PM
Setting AQL (Acceptable Quality Level) on C=Zero inspections Norman V AQL - Acceptable Quality Level 16 6th December 2006 10:41 AM
AQL - Acceptable (Assured) Quality Level Marc Definitions, Acronyms, Abbreviations and Interpretations 0 29th December 2005 02:44 AM
The time now is 10:22 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
