Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO/TS 16949 - International Automotive Quality Systems Standard > QS-9000 - American Automotive Manufacturers Standard
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 11th November 1998, 01:55 AM
Michael Garnsey
Unregistered Guest
Posts: n/a
I Say... Preventive and Predictive Maintenance - Information on procedures relating to 4.9.g.1
We are implementing a preventive and predictive maintenance plan for our automotive product lines. I was wondering if anyone had any advice, or could point me towards a good source of information on procedures relating to 4.9.g.1
Thanks!
Sponsored Links
Old 11th November 1998, 04:47 PM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
Default
I agree with Marc. You will also want to include something on predictive maintenance. Do you do fluid checks or IR checks of heat-sensitive components? Do you track/ optimize up-time?
Sponsored Links
Old 11th November 1998, 05:05 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
You're right, Roger - I forgot the predictive part of the requirement.
Old 12th November 1998, 01:04 AM
Marc's Avatar
Karma Power: 605
Default
Main points:
You system can be centralized or distributed.
Set up a database (or other substitute such as a spreadsheet) and list your equipment and make a schedule (calendar) based upon it. Then follow the schedule.
You must have a list or procedure (criteria to act upon) for each piece of complex equipment. This can be the equipment manual or manufacturer's recommendation - but must be a document with criteria. Some folks categorize some equipment in a way where certain equipment gets a 'standard' PM.
You must have evidence that each PM is performed. If you miss or delay PMs, you must be ready to explain why and the effect upon your PM program and on the equipment.
Verifying/validating the PM system should be part of your internal audits.
You must show that you have critical parts available for critical manufacturing equipment and have a plan for breakdowns (ability to continue production). Be ready to explain your threshold for catastrophy vs normal (expected) failures: ie.: You cannot plan for everything but most you can plan for. Plan with respect to availability of parts from suppliers. Consideration of production schedule loading may be discussed.
There is software available.
[This message has been edited by Marc Smith (edited 11-11-98).]
Old 26th November 1998, 01:58 AM
chen
Unregistered Guest
Posts: n/a
Default
Roger: Our compant is pursuing QS-9000 certification and would you pleasure to send me a procedure for PM?
TKS&B.RGDS!
Old 30th November 1998, 05:05 PM
Michael Garnsey
Unregistered Guest
Posts: n/a
Default
Roger,
I would like one too, if possible!
Thanks,
Michael
Old 3rd December 1998, 08:29 AM
barb butrym barb butrym is offline
Courtesy Access
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
Default
why not add one to the pdf list...eh? I am sure marc would be happy to oblige if provided with one.
Mine are too company specific .... wouldn't help
Old 3rd December 1998, 03:50 PM
Scott Knutson
Unregistered Guest
Posts: n/a
Default
Have any of you looked at TPM (Total Productive Maintenance)? This methodology is great for assuring that you have what you need with regard to Predictive and Preventive Maintenance. Marc has a string on TPM running, along with PDF files to download. Take a look. If you have other questions, let me know. I implemented a TPM system when I worked at Motorola.
Reply
Bookmarks
Tags
predictive maintenance, preventive maintenance, procedure content, procedures
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? deminika ISO/TS 16949 - International Automotive Quality Systems Standard 8 24th October 2008 01:28 PM
Predictive maintenance vs Preventive maintenance Michiel ISO/TS 16949 - International Automotive Quality Systems Standard 3 13th February 2007 11:04 AM
Preventive Maintenance vs. Predictive Maintenance - Distinction between darkafar Definitions, Acronyms, Abbreviations and Interpretations 20 22nd November 2006 01:21 PM
Preventive and Predictive Maintenance - Benchmarking Partner frank-h Benchmarking - Methods and General Discussions 6 1st August 2002 09:06 AM
QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance Frank45 QS-9000 - American Automotive Manufacturers Standard 1 23rd September 1999 12:00 PM
The time now is 06:50 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
