The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 25th August 2004, 08:39 AM
gpainter gpainter is offline
Appreciated Information Resource
Registration Date: Sep 2001
Thanks Given to Others: 10
Karma Power: 158
gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.gpainter is appreciated, and has over 900 Karma points.
Question Weld Destruct Test - Have any of you ever used this test?
Have any of you ever used this test and is it an effective test to determine weld strength. Any links to info on weld test is appreciated.
Sponsored Links
Old 25th August 2004, 09:44 AM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,448
Karma Power: 400
Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.
Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.Marc is appreciated, and has over 1700 Karma points.
I've seen different types of weld destruct from simply using a pair of pliars to try to pull a weld apart to using a tensile strength apparatus to measure the force at which the weld separates (e.g.: good weld - sheet metal - metal around weld 'tears').
Can you give us some more details of the weld destruct test you're using - And the intent?
Sponsored Links
Old 25th August 2004, 10:54 AM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 472
Karma Power: 280
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Yes..more info would help. What type of weld? RSW, MIG, TIG. I may be able to dig up some info for you if you can provide more details.
CarolX
Theater is life, film is art, and television is furniture.
Old 25th August 2004, 10:57 AM
Marc's Avatar
Karma Power: 400
I just remembered another 'weld test' I've seen - The Chisel Test. Pass / Fail, all the person did was see if a 'good whack' with a hammer on a chisel at the weld point would break the weld. There wasn't even a 'spec' on what size hammer or chisel to use!
I guess I would ask where the test is defined. Usually it's on the print if there is one. Then I would look at it and see what it calls out.
I have seen a lot of 'idiot' weld tests come out of a nonconformance issue where a test was cobbled together just so they had 'something'.
Old 25th August 2004, 11:22 AM
Jim Howe Jim Howe is offline
E-Mails Invalid or Rejected by Recipient System
Registration Date: Jun 2004
Karma Power: 0
Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.Jim Howe is appreciated, and has over 200 Karma points.
In Reply to Parent Post by gpainter
My limited experience in welding tells me that details of accepted destructive weld test and deposited filler metals can be found through the AWS (American Welding Society).
I believe it is AWS B4.0-77. I do not have a copy, sorry!
Basically destructive test are performed on sample weldments made with procedures that will be used in the production of the weldments. They are conducted for the qualification of welding procedures and consist of chemical, metallographic and mechanical test or a combination of all three.
AWS probably has a web site that will be more informative. Also there are several great books in your library that contain a wealth of background info. If all else fails call Lincoln Electric or visit their web site for more info.
Hope this gives you some direction.
Old 25th August 2004, 11:35 AM
AllanJ AllanJ is offline
Karma Power: 68
AllanJ is appreciated, and has over 400 Karma points.AllanJ is appreciated, and has over 400 Karma points.AllanJ is appreciated, and has over 400 Karma points.AllanJ is appreciated, and has over 400 Karma points.AllanJ is appreciated, and has over 400 Karma points.
There is no single test for determining weld strength. It depends on what aspect of "strength" is of interest. Destructive testing takes place on a "coupon" which is subjected to different individual tests. The ASME codes (3 and 8) used to give details of various tests, as I recall for pressure vessels. For other applications of welding, look at the applicable code, e.g. for construction.
Otherwise, try one of the weld societies or manufacturers of welding rods. And Lincoln does have a fine reputation.
Finally, if your product is being tested for an export market, it is worth checking the national or international standards that will apply as well as the compatibility of materials standards (American vs other nationals, e.g. British, German whatever.)
If you do not have the in-house facilities, look for a certified laboratory or independent weld testing service. They will be sure to have the necessary standards, equipment and so forth.
Hope that helps.
Old 25th August 2004, 12:40 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 71
Karma Power: 413
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Have a look here
http://www.aws.org/technical/b40-98.pdf
Al
Old 25th August 2004, 12:58 PM
Karma Power: 158
The test our supplier is using is based on pass/fail as to whether it pulls parent material. mig, 20-21 volts, 150-160 amps, 20-25 flow rate, c-25 shielding gas type, .030 wire diameter, el705-3 wire type. if i read their instructions correctly.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Building a Calibration Room Test Bench - Finding components, test leads, etc. Enigma666 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 8 17th May 2010 08:15 AM
Pull test standard? Wires coming off the electrodes at the weld Jmcdonald870 ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 5 12th December 2008 10:52 AM
Uncertainty in Test - Durability test, High Performance, Salt Spray chambers, etc Arte Measurement Uncertainty (MU) 5 4th September 2008 01:16 PM
Test records shall show actual test results data - 8.2.4.1 Inspection documentation clara AS9100, Nadcap and related Aerospace Standards and Requirements 4 26th January 2007 11:37 AM
Gage R&R for a Destructive Test - Weld Breakout Test RLBredeweg Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 14th June 2001 12:27 AM
The time now is 06:26 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
