Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th August 2004, 02:56 PM
PAT1L PAT1L is offline
Registration Date: May 2004
Karma Power: 23
PAT1L has less than 100 Karma points so far.
Please Help! Process Productivity - Identifying Strengths and weaknesses of a production facility
The company I work for is currently in the process of trying to identify the strengths and weaknesses of our production facility. This is going to be done through mapping processes and retraining from the executive level down. If anyone has gone through this process, any suggestions would be greatly appreciated. It is already known there will be resistance towards change on all levels of the organization. Our company shows profit on jobs but it is not known whether or not the amount of profit is acceptable, being that we could make an even larger amount of profit with just a small amount of change. For now everything is just accepted so no confrontation is created between the different departments or staff.
sincerely,
pat1l
Sponsored Links
Old 28th August 2004, 09:59 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
Default Productivity
Have you considered looking at your plant using Leam Manufacturing guidelines? These can be a real eye opener.
If you supply Ford, they have an incredibly useful website resource which includes a Lean process audit.
I also was involved looking at our most profitable job using Kaizen. We were still able to realize large improvements even on the best job in the plant!
Good luck, just by realizing you need to start you on on your way to success. The key is to do something - any improvemet tool will work if you are motivated.
Sponsored Links
Old 29th August 2004, 01:18 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Good thoughts, Caster! Thanks!
Old 29th August 2004, 01:12 PM
WALLACE's Avatar
WALLACE WALLACE is offline
Courtesy Access
Registration Date: Nov 2000
Karma Power: 67
WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.WALLACE is appreciated, and has over 700 Karma points.
Send a message via Skype™ to WALLACE
Default
PAT1L
Seems like you are prime for a team or small work group type infusion of continual process improvement.
As Caster advises you to look at the Ford model, there are many other models available to benchmark.
May I suggest you keep it simple. If you are in a position of presenting your proposals to your colleagues, I would suggest you consider using the attached visual as a starting point to allow your colleagues to view the big picture or global view of what may be involved with "fast track improvements".
Wallace.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Ask, Seek, Knock.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Process Validation - Production Line Transferring to a Different Facility Keep Smiling Qualification and Validation (including 21 CFR Part 11) 11 19th February 2008 05:42 PM
SWOT Analysis / GAP Analysis - Strengths, Weaknesses, Opportunities and Threats Andy Bassett Quality Tools, Improvement and Analysis 12 1st November 2007 10:31 AM
Productivity Objective - Production / Downtime Tracking Program Ken11 ISO 9001 - Quality Management Systems Standard 1 16th August 2007 11:41 PM
Manufacturing process design inputs - Productivity, process capability, cost targets Sushil Kumar Design and Development - Process and Product 2 8th January 2007 06:55 PM
Strengths and weaknesses of the QMS implementation process against ISO 9001 Boldy ISO 9001 - Quality Management Systems Standard 2 9th December 2006 07:21 PM
The time now is 08:50 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
