31st August 2004, 09:56 AM
E-Mails Invalid or Rejected
Registration Date: Aug 2001
Thanks Given to Others: 3
Karma Power: 0 Karma: 35
GM Layered Process Audit - Seeking the actual General Motors requirements
Could someone provide me with additional information on GM's layered audit?
I can't seem to locate any information at GMSupplypower.com other than a passing mention of layered audits in the GP5 procedure. Searching the GMSupplypower site turns up a folder titled "Layered Audits" yet contains nothing. I was unsuccessful in locating any QSB information that may contain the requirement for layered auditing also.
Any help would be most appreciated.
31st August 2004, 10:27 AM
Courtesy Access
Registration Date: Feb 2003
Thanks Given to Others: 1
Karma Power: 36
Search
It you do a search on this website for "layered process audits", I believe you will find what you are looking for. It has been discussed in these forums before.
31st August 2004, 10:47 AM
I have performed the search.....
Hi Mike,
Yes, I performed a search for layered process audits on this site and it does not yield the information I am asking about. I see that I was vague in my question about what I was looking for.
What I would like to obtain is the requirement by GM, to perform the layered audits.
In those threads that I found regarding layered audits, one of which I responded to a while back, there is nothing linking or citing the actual requirement by GM. Yes, there were mentions of the GM Layered audit but there was no mention of the specific requirement that requires one to perform the layered audit. Perhaps I am overlooking it? All I have found in the forums here is the requirement by DCX to perform Layered audits which I already had from the DCX CSR's.
I am looking for the GM equivalent. Thanks again.
31st August 2004, 10:57 AM
Involved in Discussions
Registration Date: Mar 2004
Karma Power: 34
Hello Randy,
See if the clause Layered Process Audits in the pdf file on this site helps, ***DEAD LINK REMOVED***
Reason: Dead link removed
31st August 2004, 11:22 AM
Thanks..but that is the DCX requirement
Thanks sal,
Unfortunately that is the DCX requirement which I do have. I am looking for the equivalent for GM.
Thanks for trying though
31st August 2004, 12:12 PM
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
Randy
I just looked all over and could only find a "reference" in the Global SQ Manual on Page 63. It states there is a "Layered Audit Video". Perhaps your Supplier Quality Engineer could shed some light on how to get a copy.
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
Reason: documents don't "say" - they "state"
1st September 2004, 06:07 AM
Karma Power: 34
Originally Posted by Randy Lefferts
Thanks sal,
I don't know if you have the following ***DEAD LINK REMOVED***
Like you said there is no particular mention to layered process audits in the GM specs
Also I have the one for Ford...see attachement........this, sort of hints layered audits....in the internal audit section.
It seems that only DC state the requirements for layered audits in their customers spec, Ford and GM may waiver such a requirements or don't apply it in full.
IMHO it would be advisable to contact GM and address your question to them.
1st September 2004, 10:09 AM
Registration Date: Sep 1999
Karma Power: 90
We are suppliers to DCX, Ford & GM. So far DCX is the only one that has made known its intentions for layered process audits. I received from DCX a schedule of 4 hour seminars that they are requesting their suppliers to attend.
So much for the for the 3k that our company spent on the TS audit class. Just another waste of company funds.
Sam Goody
