Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th November 1999, 06:16 AM
TL
Unregistered Guest
Posts: n/a
Angry MSA on tensile strength equipment
Hi everybody!
I'm responsible for introducing MSA (acc. to QS9) into our company. When it comes to gages the measure dimension and so on there are no problems BUT when it comes to for example tensile strength equipment (destructive test): how should the studie be conducted? I have seen the sheet from Delphi but that does not make sense.
/Tobias
Sponsored Links
Old 29th November 1999, 10:30 PM
pdboilermaker
Unregistered Guest
Posts: n/a
I think that that correct to perform this type of study can be found in the MSA manual. It is back in the appendix (c? g?) and tells how to do this. My basic understanding is that you essentially make a run chart for each of the tests that you perform. Anyway, I dont do calibrations, I have just read the extremely dry and boring MSA rag a few times. You better double check
Sponsored Links
Old 30th November 1999, 03:18 AM
TL
Unregistered Guest
Posts: n/a
Question
Hello!
No, I don't thinkt this procedure is described in the MSA manual. I have read this a couple of times as well.
/Tobias
Old 30th November 1999, 02:31 PM
TL
Unregistered Guest
Posts: n/a
Look!
Hi Don!
I have read most of the topics of Calibration and MSA but no one have had a good answer to this question. I think that is somewhat strange because a lot of companies must have faced this problem.
Have you any suggestions where the answer can be found?
/Tobias
Old 1st December 1999, 01:33 AM
Don Winton's Avatar
Don Winton Don Winton is offline
dWizard
Registration Date: Nov 1998
Karma Power: 63
Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.Don Winton is appreciated, and has over 400 Karma points.
Clown
Try This:
http://Elsmar.com/ubb/Forum4/HTML/000058.html
Regards,
Don
Old 1st December 1999, 09:34 AM
Don Winton's Avatar
dWizard
Karma Power: 63
Clown
<FONT COLOR=#B30000><BLOCKQUOTE>I have read most of the topics of Calibration and MSA but no one have had a good answer to this question.</BLOCKQUOTE></FONT>
I guess that would depend upon your definition of good. I assume then that the paper on R&R for attribute data did not help, nor the paper on process capability for attribute data.
<FONT COLOR=#B30000><BLOCKQUOTE>Have you any suggestions where the answer can be found?</BLOCKQUOTE></FONT>
I guess MSA is in the eye of the beholder. Suggestions:
  • A run or control chart on the variable data rather than the attribute data.
  • A control chart on the attribute data.
  • Process capability on the variable data.
  • Process capability on the attribute data.
Just because the AIAG publishes a book on MSA does not mean it is all-inclusive.
Regards,
Don
Old 1st December 1999, 10:23 AM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
In the bibliography of the MSA manual, it lists a paper by Donald Wheeler (a good SPC/MSA/DOE expert) on MSAs done on Destructive Testing equipment. I would call AIAG and see how you can obtain a copy. Also, check the ASQ press catalog and look for a SPC book that has something on MSAs. I would also recommend Wheeler's book on SPC. Anyway, there are some other resources other than the MSA manual (as has been mentioned). The good news is that you are not the first one that has tried to do an MSA on destructive testing equipment!
Old 2nd December 1999, 04:02 AM
TL
Unregistered Guest
Posts: n/a
Thumbs up
Thanx Roger!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
When to use Linearity and Bias - appropriate for paper tensile strength? Mickyr Quality Tools, Improvement and Analysis 6 26th May 2008 02:42 PM
Laboratory for Checking Tensile Strength using UTM (Universal Tensile Machine) ignatiuswong ISO 17025 - Calibration, Measurement Gages and Test Laboratories 13 29th December 2007 12:32 PM
Ford's for material test methods for tensile strength, compression deflection, etc. qualityengineer Customer and Company Specific Requirements 4 7th June 2006 10:57 AM
What distribution should I expect a tensile strength test to fit? Matthew_Hopkins SPC Monitoring and Statistical Analysis Techniques 10 11th January 2006 02:59 AM
What SPC method that I've must to control characteristic tensile strength? Lita SPC Monitoring and Statistical Analysis Techniques 1 11th July 2005 12:46 PM
The time now is 02:08 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
