27th September 1999, 09:00 AM
Calibration of Timers to NIST - How are digital and analog timers calibrated?
28th September 1999, 05:52 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Subject: Calibrating Stop Watches
Date: Sat, 18 Sep 1999 16:45:47 -0400
Organization: Genzyme Corp.
Hello Marc,
I just stumbled across your website and one of your topics was calibrating stopwatches. We are looking at buying a device that measures the frequency of the crystal oscillator inside. There are no eye hand coordination errors etc. You simply place the timer/stopwatch on the device and it determines the number of seconds per wek or month it is off. It will work with quartz and mechanical type watches. The device model number is a Q Test 6000 and it is made by Witschi Electronics. They may be reached at 1-800-882-7977. We are currently testing the watches and timers we have by comparing them to a frequency counter. This device will save us a considerable amount of time. I just thought you may be intersted in it
Morrill Reynolds III
3rd December 1999, 12:55 PM
Registration Date: Dec 1999
Karma Power: 89
I just read your post on calibrating timers and stopwatches. There are a few different methods to do this. The simpler method I have used involves first running an experiment with numerous iterations between the operator and the standard wherein you start the stopwatch and standard and the same time and stop the stopwatch and standard when the stopwatch reads exactly 10 seconds. Repeat this process at least 25 times (I did it 100 times for about 10 seconds each). Record the data and calculate a maximum deviation between readings. Add this to your measurement uncertainty as operator error. For a standard, use either a time mark generator (such as used for an oscilloscope calibrator) or other suitably accurate signal source. Use the start stop function on a frequency counter (I used a H-P 5335A counter). Set the repetition rate of the source to either 1 KHz, 10 KHz, 100 KHz or 1 MHz. Reset the counter readout to zero. Press start on the counter at the same time as pressing the start on the stopwatch. Let them run for an adequate amount of time (do uncretainty caluclations for the combined uncertainty of the counter, the signal source and the operator uncertainty), and allow enough time to minimize the impact of operator uncertainty. Be sure you get 4 to 1 or greater Test Uncertainty Ratio. When you stop both, be sure to look at the stop watch display to try to stop at a nominal (or close). Record readings, calculate deviations.
I do NOT recommend measuring the timebase in a stopwatch. You will get very mixed results, and MAY damage the stopwatch.
There is anohter method that I can look up if needed. Some nuclear industry contractors make up test fixtures that start the stopwatch and the standard at the same time. I have not been able to locate one of these.
You can email me at rn0414@email.sps.mot.com for further questions.
9th October 2002, 04:01 PM
Oven Process Timer
Having completed a search for "Timers" and thinking that some of the responses may be overkill, I would like to present the following from our Coating procedure for Pressure Vessels (Tanks), big enough to work in.
Gel Bake-275 Deg. F. 40 to 50 minutes....Depending on vessel configuration. Longer for vessels with false bottoms and/or portsights
Final Bake-360 Deg. F. 110 to 140 minutes...Depending on vessel configuration. Longer for vessels with false bottoms and/or portsights
We have (2) Honewell Digital Temperature Indicators to monitor and set temperature and a Process Timer that turns off the heat to the oven at the time you set it for. It has been proposed that we install a Bi-Metallic Thermometer at the point where the thermocouples are located to compare the meters. To satisfy a potential calibration inquiry. The thermometer would be in 1 or 2 deg increments, calibrated by an outside lab. We cannot afford to lose the time to get the equipment calibrated by an outside lab. They also do not want to purchase extra equipment to install during the time it would take for calibration outside. The timer would be checked against the electric clock nearby or somebody's timepiece. Don't laugh. The reasons given is that the time for baking and the varying temperatures are estimates arrived at through years of performing this process.
Can an Auditor question the methods proposed with such varying baking times and temperatures? The time would be +/- 2 minutes and the temperature would be +/- 5 deg.
Take it easy on me.
10th October 2002, 09:21 AM
Registration Date: Feb 2001
Karma Power: 41 Karma: 146
Re: Oven Process Timer
Take it easy on me.
Here is a TRACEABLE, FREE alternative, and you can do it yourself! First, go to
http://ts.nist.gov/ts/htdocs/230/235/105-5.pdf and download the NIST standard for stopwatches. Then, ftp to time-b.nist.gov/pub/daytime/ and get nistime-32bit.exe and download this handy little app that will set your computer clock to the NIST UTC timeserver (make sure you do it a few times to reduce the effects of 'net delay). Start your timer, run it 3 hours, stop it, repeat. Make sure you run the NISTime app before the stop and start for full traceability. There you go, no counters, only a computer connected to the net. Your uncertainty will be about 0.2 sec, with a tolerance (at least) ten times greater, so you'll be golden.
For your temp, I wouldn't use a bimetal, but there are some very reasonably priced digital thermometers (<$80) with a k-type thermocouple included. It is cheaper to have a digital thermometer calibrated, and they are much more accurate, so you're better off all around.
Ryan
10th October 2002, 09:44 AM
Ryan,
Great response. I'll let you know how it goes.
10th October 2002, 12:45 PM
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
Energy
Can you verify the coating after processing anyway ?
i.e. do you measure thickness, adhesion, etc ?
10th October 2002, 01:03 PM
Yes
