If you are using Minitab 16, there is a very nice step by step guide on how to do capability analysis for binomial data.
See
Assistant---> Capability analysis--> Binomial Capability
Make sure to read to guidelines, they are very informative.
For intance it says (verbatim):
Binomial capability analysis determines whether the % defective meets customer requirements.
Guidelines
Collecting the data
Collect data from a stable process.
Process capability determines the capability of the current process and can also be used to predict the future, ongoing capability of the process. When you use data from the current process to predict future performance, the current process must be stable and in control. If it is not, you cannot accurately predict future capability.
In the Diagnostic Report, Minitab displays a P chart that you can use to determine whether your process is stable. Investigate out-of-control points and eliminate any special cause variation in your process before continuing with the capability analysis.
Collect data in subgroups (samples, lots).
A subgroup is a collection of similar items that are representative of the output from the process you want to evaluate. The items in each subgroup should be collected under the same inputs and conditions, such as personnel, equipment, suppliers, or environment.
Subgroups must be large enough.
If some subgroup sizes are too small, you cannot adequately assess process stability. Minitab checks that the subgroup size is large enough based on your data and reports the subgroup size that is needed to produce a reliable control chart.
Subgroup sizes can be unequal.
Subgroups can vary in size. For example, if a call center tracks 100 incoming calls each hour and counts the number of unsatisfactory wait times, all of the subgroup sizes are 100. However, if the call center tracks all of the incoming calls during a randomly selected hour of the day, the number of calls is likely to vary and result in unequal subgroup sizes.
Collect enough subgroups.
To obtain accurate estimates, you must collect enough subgroups. The number of subgroups required depends on the average number of defective items and on the subgroup size. It is generally recommended that you collect at least 25 subgroups over a long enough period of time to capture the different sources of process variation.
Minitab displays the confidence interval of the % of defective items, which indicates the precision of the estimate. If the interval is too wide for your application, you can gather more data to increase the precision of the interval.
Count the number of defective items in each subgroup.
A defective item has one or more defects that make it unacceptable. If you can determine only whether an item is defective, use this analysis. If you can also count the number of defects on each item, you may want to use a Poisson capability analysis to evaluate the defects per unit.
Interpreting the results
% Defective and PPM (DPMO) measure the defect rate of the process.
Regards,
Reynald
