In clause 7.5.2. Cleanliness of product describes situations in which an organization must document its product cleanliness requirements (as I understand it).
The clause mentions the following:
Could you give me examples of how the other cases are applied in other contexts?
Thanks.
I have a medical device that needs to be sterilized prior to use. However, the sterilization of this product is performed by an external company (my company only manufactures the device). Which case clause may apply?The organization shall document requirements for cleanliness of product or contamination control of product if:
a) product is cleaned by the organization prior to sterilization or its use;
b) product is supplied non-sterile and is to be subjected to a cleaning process prior to sterilization or its use;
c) product cannot be cleaned prior to sterilization or its use, and its cleanliness is of significance in use;
d) product is supplied to be used non-sterile, and its cleanliness is of significance in use;
e) process agents are to be removed from product during manufacture.
If product is cleaned in accordance with a) or b) above, the requirements contained in 6.4.1 do not apply prior to the cleaning process.
Thanks.
