SI 24 from https://www.iatfglobaloversight.org/wp/wp-content/uploads/2022/05/IATF-16949-SIs-May-2022.pdf
NOTE 3 For highly automated processes (e.g., semiconductors, machining, welding) where the control method (i.e., specification/tolerances, sample size, frequency) is controlled by a system (e.g., MES - Manufacturing Execution System or similar), summary control information is acceptable with direct references or linkage to the system that manages the detailed process control information.
So for welding we have:
1. Process Characteristic - Voltage, Wire feed speed, Amperage, Travel Angle, Torch work angle
2. Process Specification - per Program #13456A
3. Measurement Technique - per Program #13456A
4. Sample Size - per Program #13456A
5. Frequency - per Program #13456A
6. Control Method - per Program #13456A
7. Reaction plan - no reaction is possible, because:
a) parameter settings have only target values, but range could not be set, so any real value is good
b) robot is not equipped with control system to detect real value has exceeded parameter setting range
c) robot does not display any alarms
Does your control plan look like this?
Are you going to revise control plan to match this?
So, customer is buying cat in the sack, because won't get this program as part of PPAP package, because supplier is protecting own know how.
The only one supplier in the world who can weld. Interesting.
Only because "control plan" could be "too huge".
Yes, 5 parameters requires 5 lines, so maybe it's better to put "1. Welding parameters"
Of course brake disc control plan deserves one page only.
Casting per software, machining per software and that's it.
What are they doing there?
