Good Day.
I would like to ask some questions/guidance with regards to EtO validation.
Postive EPCD during half cycle are acceptable if they have demonstrated greater resistance than the IPCD providing a “worst-case challenge” for routine processing. However all IPCD should test negative”
- Based on the above requirement, we have difficulty on judging the results. Is there any other way or a justification that can be used to accept the above result.
Thank you in advance. Hoping you help and guide us.
- During our half cycle we put IPCD and EPCD, but the result was there are BI growths on IPCD as well as EPCD, is this considered as a failed result?
- We repeat the half cycle, this time both IPCD and EPCD are all negative, is this also a failed result?
