Our current Risk Management SOP is based on ISO 14971 and described the "Safety Risk Management" process. Should we also indicate in this same procedure the "Security Risk Management" process, as described for instance in "AAMI TIR57:2016/(R)2019 - Principles for medical device security—Risk management", and its interaction with "Safety Risk Management" ?
I would NOT directly include (cyber)security in the SOP for "14971" compliance. From memory, AAMI TIR57 suggests establishing a parallel process (essentially identical) to the 14971 process, and then 'linking' them (as appropriate) when security design decisions impact the risk profile of safety concerns and
vice versa. I like this approach for medical device manufacturers.
On the surface, maintaining two parallel document sets may appear to be increasing the work load and increasing the number of documents. I think the advantages to keeping them separate are:
1) Cybersecurity is a rapidly changing landscape... such that even
documenting how security risks are addressed may come under scrutiny, forcing radical changes to
those documents. Documenting
safety (in the context of 14971) is an area where people are relatively comfortable reviewing slightly different files, and there are consensus approaches to default to.
2) Cybersecurity has a radically different concept of
harms than Safety does. Inviting the two different types of harms to live in the same SOP is inviting trouble, IMO.
3) The outputs of a cybersecurity risk management process
could be leveraged in ways that the outputs of a safety risk management plan would not be. My experience has been that safety risk management files are almost exclusively only used internally, and are only occasionally reviewed by external groups such as regulatory authorities or their representatives. A well-constructed suite of security risk management files should allow a manufacturer to rapidly answer questions from prospective customers... such as when a customer won't buy the product unless the manufacturer fills out an MDS2 form or answers a prospective customer's questions.
Point 3 is a long-winded way of saying that in the area of cybersecurity: there is no consensus approach that the medical device isn't itself inherently risky or that it isn't introducing security risks. With safety, there is a common understanding (enforced by following established consensus standards) that a device approved by regulatory authorities is
safe. I would segregate the areas where consensus exists from the area where there is no stable consensus. Tailor the security risk management process to satisfy its needs, and feed it into safety risk management as necessary.
