terranceyu
Hello to covers,
Right now, I have a tough situation, and supplier is not going to give in our findings.
Details are explained in the below statement:-
Production found LCD pins misaligned and not able to fit into PCB holes. ( pin is misaligned by 0.2 mm measured from the centre of pin to the edge of glass). Almost 40% of the LCD can not fit to the PCB. All the parts were purged out and return to reject warehouse. IQC checked the PCB hole, it is ok. Then, IQC took 3 pcs LCD from each three lots, some lot found: 2 pcs reject, 1 ok, and some is 3 pcs reject. We would like to charge the supplier on the sorting cost to segregate the LCDs, and supplier is not agreed.
Instead, they wanted us to measured according to AQL 1.0 (in other means 80 pcs for each lot they delivered), as they use AQL1.0 sampling for their minor defect quality control. They even said, if you like to strictly tighten the quality standards ( we are applying the AQL=0.25), they can either increase the price or we need to find another LCD vendor, as they can't meet our requirement.Now they request us to measure 80 pcs and tell them the result.
I am wondering is it appropriate for measuring 80 pcs, since we know there is a problem in their process, causing 40% of failures in the end of line. If their process average is very capable and stable, why should they want us to check until 80 pcs, and feedback them the result? And in AQL, is there a clause to state that measurement must be according to AQL, as we normally take 5 pcs for mechanical measurement.
Please comment and advise.
