Variable Data Test Never Fails - Page 2
Some Related Topic Tags
pull test, testing (general testing topics), variables data
  Post Number #9
Old 10th September 2018, 09:45 PM
bobdoering's Avatar
bobdoering
Re: Variable Data Test Never Fails
10X the spec times 10X the coffee....it'll get you there.
  Post Number #10
Old 11th September 2018, 08:58 AM
John Predmore
To satisfy yourself that your inspection apparatus is working properly (and able to distinguish defective glue joints), prepare test specimens where you compromise the joint integrity, for example by applying less glue, or remove substrate material to reduce surface area. (As a safeguard, clearly label your defective test samples so you donít lose sight of them and they get shipped as valid product.)
If you want to understand better what is occurring within the joint, instead of a force gage use a tensile tester. A tensile tester measures both force and displacement. Force x Distance = Work. The area under the Force/Displacement curve is Energy. A tensile tester can also apply force at different load rates or at different angles, which might provide valuable information.
Visitors Currently Viewing this Thread: 2 (0 Registered Visitors (Members) and 2 Unregistered Guest Visitors)
GR&R for a test fixture that outputs variable data per measurement e119687 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 31st October 2017 08:21 AM
Wavetek 9100 fails self-test - Need Service Manual source Heckerh General Measurement Device and Calibration Topics 13 26th October 2016 03:59 AM
DOE - Variable and Discrete Data - Minitab Kath A Using Minitab Software 11 22nd November 2010 11:16 AM
Attribute vs. Variables Data - Variable data preferred over Attribute - Auto Industry amanbhai Statistical Analysis Tools, Techniques and SPC 3 14th June 2005 12:04 AM
Is X-Ray Data Variable or Attribute? How to do a capability study? Caster Statistical Analysis Tools, Techniques and SPC 3 23rd May 2005 03:33 PM
The time now is 11:58 AM. All times are GMT -4.
Misc. Internal Links
