MAG (MAINTENANCE ANNEX GUIDANCE) Change 4 Section 10 Release and Acceptance of Components paragraph b states:
The FAA Form 8130-3 should include the EASA Part-145 release to service
certifying statement with the EASA Part-145 Approval Certificate number in block 12, and specify any overhaul, repairs, alterations, Airworthiness Directives, replacement parts, PMA parts and quote the reference and issue/revision of the approved data used.
According to this requirement replacement parts, including PMA parts should be listed in block 12 of a Dual Release FAA Form 8130-3.
My questions are:
Thanks for your input.
Mike
My questions are:
- Am I interpreting that correctly?
- If so, would some please provide me with an example of how you are listing your parts in block 12?
- Are you using any software such as Component Controls Quantum?
- If so, are you using Component Controls Quantum to create your Dual Release FAA Form 8130-3?
Mike
