raghu_1968
The query is related to the limit for Humidity which has to be maintained in (Pharma area) clean room.
As per the guideline 14644, the typical set range of relative humidity is 30 to 65%.
During my audit to one of the supplier facility, the limit fixed for the relative humidity is 35 to 70%.
However they have qualified the area with the 70% RH.
The concept is, the temp. & RH maintained at clean room should cover our stability conditions of 25°C & 65% (RH). Here the value 70% is beyond the 65%,
The upper limit of fixing the value of 70% is acceptable?
Regards / Raghu
Regards / Raghu
