Marc L
I am a new with Minitab and this is my first post. Can any one let me know how to determine the process capability study using minitab 17?
Mill produces thin plates with a nominal thickness of 2 mm and width of 1200 mm. One hundred sheet, the average thickness of the coil 2,01mm is calculated, a standard deviation of 40 ?m. Product quality, the thickness tolerance of +/- 0.14 mm.
a) Determine the process capability.
b) the thickness of the thin plate set tolerance limits, so that a 95% probability that the boundaries of the tolerance as many as 99% of the population.
Marc
Edit/Delete Message
Marc
Edit/Delete Message
