MetroBioCen
Hello everybody
I'm here again with another question for you.
I have to determine the uncertainty in the calibration of a Pyrogen Test Processor. This device is simply a digital thermometer with a thermocouple sensor. Well, in fact, with multiple thermocouple sensors (about 75) and the device scan every 15 minutes for all thermocouples.
The calibration procedure that I'm using is as follow:
I put the thermocouples in a stable bath (stability about 0,01 ?C)
When readings are stable, I take reading of all the thermocouples and the standard that I use.
My question is: For a type B uncertainty calculation:
Should I consider the uncertainty of the thermocouples and the digital indicator independently or;
Should I consider the uncertainty of the sensor-indicator as a whole.
Thanks in advance.
Thanks in advance.
