Elsmar Cove Quality DiscussionsAS9100D - Good ways to document an internal audit plan / scheduleThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
AS9100D - Good ways to document an internal audit plan / schedule - Page 2
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Some Related Topic Tags
as9100 revision d (2016), audit plans and audit frequency, internal audits, process audits
  Post Number #9
Old 17th April 2018, 07:55 AM
Mike S.
Re: AS9100D - Good ways to document an internal audit plan / schedule
The OP didn't ask what was required by the standard or auditors.
I use a spreadsheet as well. I set date goals for certain audits, and am flexible as to the realities that sometimes require those planned dates to move around.
Create a plan/schedule and adjust as necessary. Kinda how you run much of a business, huh?
  Post Number #10
Old 17th April 2018, 01:36 PM
AndyN's Avatar
AndyN
Let Me Help You Re: AS9100D - Good ways to document an internal audit plan / schedule
In Reply to Parent Post by Mike S. View Post
And I'd suggest that, to set a calendar and then be adjusting dates etc isn't what is, as the OP requests, a "good way to document an internal audit plan/schedule"...
Doing internal audits isn't a time based thing - CB audits are. Internal audits need to go where the "squeaky wheels are" and those do not happen to a 12 month schedule. I recall, a couple of versions ago, ISO 9004 had a very good guideline which stated something along the lines of "scheduling should be flexible to all for things uncovered at each audit". If you plan something and the plan keeps changing, all we know is, the plan isn't a good one.
  Post Number #11
Old 17th April 2018, 03:16 PM
Mike S.
You make a lot of assumptions, Andy, that ain't necessarily so.
I didn’t say anything about 12 month schedules, you did.
Inputs to my spreadsheet are based on discussions and reviews of previous audits, risks, importance, introduction of any new processes, etc. etc.
If you make plans that never change, well, God bless you, you must be better than everyone else at planning. If you never make plans, well, God bless ya anyway.
  Post Number #12
Old 17th April 2018, 04:15 PM
AndyN's Avatar
AndyN
Correct, you didn't. My comments, not assumptions, are based on what probably 99% of organizations do.
  Post Number #13
Old 17th April 2018, 10:38 PM
jack770214
In Reply to Parent Post by Joeem View Post
Help. Any good ideas for a good way to document a internal audit plan / schedule? I have 16 processes to audit. What program should I use to create something to show what is audited and when and by who?
Sent from my Pixel 2 using Tapatalk
After you set up your schedule our company uses an audit score card with weighted variables to show what gets audited either more frequently or intensely. Those variables are for example processes that were root cause for RMA, Major or Multiple non conformities found by internal, external, or customer, new and or changed processes, negative trending KPIs etc. It can help to give some direction to your plan not sure if its mandatory but its a good practice to make the plan risk based and not just for the cert.
Sent from my LGMP260 using Tapatalk
Thanks to jack770214 for your informative Post and/or Attachment!
  Post Number #14
Old 18th April 2018, 08:33 PM
QMS Tom
Regarding your 16 processes, is every requirement of AS9100 encompassed in these? Just be sure to audit your processes and all AS9100 requirements as well as statutory and regulatory requirements.
Audit schedules are to be based on importance and prior audit results. Rank the processes in this way.
Create a matrix (like others have suggested, processes on one side and months across the top). Schedule the audits ensuring that you can demonstrate consideration for importance and prior audit results.
Audit the important stuff. The "not so important" can wait...audit these once per year.
Audit records should should what objective evidence was reviewed to draw your audit conclusion.
  Post Number #15
Old 19th April 2018, 06:25 AM
AndyN's Avatar
AndyN
Audit "schedules" aren't what's required. The standard doesn't mention them, calendars or any time-based plan. It simply says an audit program (one or more audits) based on importance etc. Audits should be driven by QMS events, such as:
Changed/new processes, people, product, suppliers, customers/requirements, regs.
Anything which didn't go "to plan" - performs poorly or better than expected. That doesn't happen to a schedule.
The audit frequency etc has to be defined, but that doesn't mean all audits have to be done at the same frequency. True, some things in the business are more important, so get to those first. As with calibration, doing audits to a predicted calendar rather than by use, doesn't make for effective internal audits.
Visitors Currently Viewing this Thread: 2 (0 Registered Visitors (Members) and 2 Unregistered Guest Visitors)
Developing a ISO 9001:2015 Internal Audit Plan and Schedule Adaym ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37 22nd March 2018 10:14 AM
Please share your IATF 16949 Internal Audit Plan and Schedule David J Quality Internal Auditing 13 2nd September 2017 07:08 AM
Internal Auditing to ISO 9001 - How to schedule/plan and perform an ISO audit Crusader Internal Auditing 31 15th July 2017 09:16 PM
Internal Audit Plan/Schedule wanted trishalei Internal Auditing 19 10th February 2015 08:34 AM
R2 Certification Internal Audit Plan, Audit Sheet, and Schedule Lynn C Manufacturing and Related Processes 2 17th September 2013 10:50 AM
The time now is 03:13 AM. All times are GMT -4.
Misc. Internal Links
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
