... Now here is where I find it complicated, I need to backtrack all repairs made with said failed wrench, but when did it fail? It was found in tolernace, it left in tolerance. During the calibration process it fails, how do I decide which of the repairs are "valid" and which ones are not?
Any advise \ assistance words of wisdom are welcome!
This is called either traceability: Finding the tool or instrument used on a product when the product fails, or in your case reverse traceability: finding the product when a tool or instrument fails.
Unless the wallet opens to purchase sophisticated torque monitoring in real time, the only way to narrow down the failure impact time frame is to test the wrench more frequently.
The use of an electronic torque tester similar to this
https://buy1.snapon.com/catalog/ite...roup_ID=739762&store=snapon-store&dir=catalog can be used before each shift when the tool is checked out to an individual. If you know all assemblies that individual worked on during a shift, the scope of your problem is narrowed. It can also serve as evidence the user can properly use the wrench (there are many who think they can, but it can be demonstrated they cannot). If you maintain the link between assemblies, technician, and tool in a small time frame it may help you.
(My best example is a failed torque
sensor on our calibrator! Had to find all wrenches that sensor was used to calibrate--with appologies to Andy....
--and then find all aircraft where those wrenches were used!
Fortunately, it was a high sensor, so the wrenches and uses were few. We had recently and satisfactorily completed a proficiency test and were able to show that the sensor was good up to a specific date. So all wrenches cal'd after that date were recalled, and those wrenches lead to jobs on 5 aircraft. The affected bolts were retorqued to satisfy the impact investigation.)
