Q
QCOcra
Hi CE Gurus!
I have researched heavily into CE Marking for our product and have received mixed responses from different test facilities and have become even more confused by the CE Marking requirements.
We sell solenoid actuator type devices all over the world including Europe. These can go to end users, such as laboratories, or to manufacturers who incorporate it into their system before resale.
These actuators can be in incorporated into medical devices, bioskids, industrial rigs, or beer machines.
The actuators use a mechanical spring to extend the rod and a solenoid to retract. They operate at 32 VDC max and can have hall effect sensors added to the actuator to provide feedback on position. Sensors operate around 10-32 VDC.
I have been told since it is "inherently benign" and it does not fall under the EMC directive. Also, if it doesn't fall under any safety directive then the RoHS directive would apply and it can be CE Marked under only that directive. I have also been told by another source that since it is a component it would not require CE Mark.
From reading the Low Voltage Directive, as it is below 75 VDC I have concluded it does not fall under that directive.
The more I read the more confusing it becomes. Any help would be appreciated!
Thank you!
Thank you!
