Re: Need CAPA example to provide traianig
Duke I will be glad if you could describe me about flat tire example Thanks inadvance
You mean you've never had one??? Lucky you. Guess after more than 30 cars (not counting rental cars) the odds are against me?
Here's just one of many I use in my root cause analysis training:
1. Tire looks somewhat deflated. Why?
1.1 Wasn’t properly inflated when installed, or
1.2 Some intentionally let air out of tire, or
1.3 Tire is leaking (it was this one). Why?
1.3.1 Valve stem is leaking, or
1.3.2 Aluminum wheel is leaking, or
1.3.3 Interface between wheel and tire is leaking, or
1.3.4 Tire has a puncture (it was this one; this is the Physical Cause to be corrected, plugging the hole in the tire or replacing tire). Why did it occur?
1.3.4.1 Someone intentionally punctured it, or
1.3.4.2 Driver ran over something hazardous (it was this one). Why?
1.3.4.2.1 Didn't see a hazard in the road, or
1.3.4.2.2 Tried to avoid rear-ending another vehicle and swerved off the road hitting a hazard, or
1.3.4.2.3 Habit of driving through the median to avoid heavy traffic (it was this one; this is the System Cause, which is the root cause; only by changing driving habits would problem not likely recur due to same cause)
