A6Intruder
Having an 'animated' discussion with a peer whose opinion I value highly; however on this topic we disagree, and seeking some thoughts from the assembled multitude of QA pros.
As9100 (whatever) tells us that control of monitoring and measuring equipment is to be done at specified intervals, and that we can set them based on whatever criteria we choose/deem appropriate.
The gear in question happens to be some floor fitting interface fixtures, used to 1) locate the monument-to-floor fittings prior to bonding. The locations are derived from the model and the fixtures were machined and then digitally scanned to a magnitude greater than the tolerance of the fittings' locations. And yes the scanning equipment itself was all calibrated.
Here is the point of contention: since these plates are made of 1/2" thick aluminum any damage that affects the fitting interface will be quite visible and because of that, I called for a 'One Time Only (OTO)' cal interval. The quality plan for this project and project unique cal process defines this and also allows it as long as no damage to the fixture is present.
My friend does not accept a OTO; instead he maintains that I should have some interval, even if it is a 5 year interval.
When I ask him why, he just repeats himself. I don't want to put us in a position of missing a 5 year window, and at the same time am confident any damage that would impact the fitting locations would be blatantly obvious.
Your thoughts and comments please.
Thanks.
Thanks.
