The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Document Control Systems, Procedures, Forms and Templates
Forum Username
Wooden Line
Procedure vs. Work Instruction (WI) - What is the difference? - Page 10
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Related Topic Tags
definitions, sop (standard operating procedure), work instructions (wi), policies and policy statements, procedures (general), differences (general)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  Post Number #73
Old 17th June 2015, 01:27 AM
sms4u
Re: Procedure vs. Work Instruction (WI) - What is the difference?
Thanks to All. I appreciate your kind help.
I got the clear idea of Procedure and Documentation.
But still I am baffled regarding Process. I am aware of that Process uses resources which transform input to output.
As mentioned earlier, we are having many activities,
Do we have to make a process flow chart for all?
Do we have to write procedure for all those Procesess?
I Kindly request to help me out, as I am new to Quality Management System.
Sponsored Links
  Post Number #74
Old 17th June 2015, 02:28 AM
John Broomfield's Avatar
John Broomfield
Lightbulb Re: Procedure vs. Work Instruction (WI) - What is the difference?
In Reply to Parent Post by sms4u View Post
sms4u,
A process or work uses resources and controls to transform inputs into output.
The resources include facilities, equipment, skills and knowledge.
The controls include procedures, care and coordination.
The procedures may not be documented (see the definition of procedure).
We also know that processes comprise activities. End to end processes usually involve more than person, function or department.
For this reason an activity is not considered a process.
So, to answer directly your two questions with respect to conformity to ISO 9001:
1. Do we have to make a flowchart for all activities? - No.
2. Do we have to write procedure for all processes? - No.
You and your colleagues decide if the procedures (for processes) or instructions (for activities) need to be documented so their work is effectively planned, operated and controlled.
They assess the likelihood and consequences of the process or activity going wrong when done by people made competent by their system. We cannot decide for them.
John
Sponsored Links
  Post Number #75
Old 13th May 2016, 03:13 PM
Krocpok
Going back to difference between instruction and procdures, I'll add one more point of view. I agree with the previous opinions that the best disctinction is that procedures answer the question: who / what? and instructions: how? It's generally up to you how you name your documents but here's the reason why we decided to transfer that logic into our procedures..
When deciding what should be the disctinction between procedures and instructions we used only one criterion. It was: the way that the want a document to be approved and controlled.
Defining employees responsibilities is very important subject. Therefore, the documents that establish or change rights and obligations for employees should be approved by the top management. In practice, these are the documents that answer the question: "who does what?". And - according to our control over documents procedure - these documents are called procedures.
The documents explaining the way of performing some task, without (or "almost without") establishing any new obligations are called instructions (in practice they answer the question "how?") - and these are approved by a process owner (there is no need for these documents to get "higher" approval, since they doesn't change the distribution of responsibilities in the company).
The documents that determine the form of preparing a records are called "forms". These are approved by process owner (in simplified way).
For ex:
- the document that states: 1. quality controller performs the control and records its results, according to the control plan, then 2. warehouse worker transports the material to the warehouse, then: 3. quality controller marks the material with label and color (ref. to material marking instruction) - is procedure.
- the document that states how material should be marked (1. use orange paint for material A, blue for B, 2. put a label on the top of the containter in a visible place etc.) - is instruction.
If all of these matters were put into one document (document explaining "who, what and how?") - it would still be called a procedure because it should be approved by the top management. But I avoid mixing these subjects in one document because then any technical change in the way of performing a task would require approval on a higher level which is unnecessary. It's better to have a reference to instruction.
Therefore, I think that you should decide what should be the way of control over various documents in your company. Which criterion, which document attribute determines that the control should be different? Then, make the distinction between them. It is unnecessary to have 2 kinds of documents controlled in the same way or one kind controlled in 2 different ways.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Process Flow Chart is a Work Procedure or a Work Guide, or a Work Instruction jm1231 Document Control Systems, Procedures, Forms and Templates 28 9th March 2012 12:52 AM
Can a WI (Work Instruction) be alone without depending on a Procedure? QAMTY ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5 30th September 2011 05:02 AM
What is the difference between a Procedure and a Work Instruction? abcauto ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2 15th July 2010 07:29 AM
ECN Procedure or Work Instruction (WI) for Product Changes example needed shaggy1812 - 2011 Document Control Systems, Procedures, Forms and Templates 8 22nd September 2006 02:49 PM
How do you reference a WI (Work Instruction) to a procedure? mickeld - 2005 Document Control Systems, Procedures, Forms and Templates 16 18th June 2004 10:07 AM
The time now is 02:16 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
