The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > Aviation, Space and Defense Standards and Requirements > Federal Aviation Administration (FAA) Standards and Requirements
Forum Username
Wooden Line
Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
faa (federal aviation administration), pma (parts manufacturing approval), tso (technical standard order), tsoa (technical standard order authorization)
Reply
  Post Number #1
Old 27th May 2015, 07:47 PM
PHANTOM
Please Help! Basic questions about earning TSOA (Technical Standard Order Authorization) and PMA
1. I'm trying to understand what it really takes to earn a TSOA. Its not just about getting design approval and being able to throw together a part you can sell. Does the FAA look at say, material control, MRB, quality system, the qualification of your workers perhaps? How much scrutiny comes from the FAA or do they simply say "Your paperwork looks good, your test data is good, call us when your done".
2. I am guessing OEMs want to be quite particular about who is holding PMA for their necessary parts. Does the OEM have any say in who gets PMA or is it strictly an FAA decision? Does the manufacturer have to satisfy both? Is it common for a manufacturer to receive design data from the OEM?
Sponsored Links
  Post Number #2
Old 31st May 2015, 10:57 AM
Stijloor's Avatar
Stijloor
Re: Basic questions about earning TSOA (Technical Standard Order Authorization) and P
A Quick Bump!
Can you help a fellow Cover??
Thank you very much!!
Sponsored Links
  Post Number #3
Old 5th June 2015, 06:01 AM
errhine's Avatar
errhine
In Reply to Parent Post by PHANTOM View Post
In Short:
1. There is a lot that goes into earning the TSO Authorization letter. After all of the work with the ACO for certifying the design, the ACO will request the local MIDO to oversee the production. This includes multiple audits with a frequency and type depending on your risk level. I would recommend reading FAA Orders 8120.22 and 8120.23 to start with. The RGL is your best friend and all of the current orders can be found there. http://rgl.faa.gov/
Ensure that you have a good relationship with both the ACO and the MIDO during the application process and while you maintain the Production Approval.
2. As for PMA, The easiest way to obtain approval is through the airframer (OEM). All it takes is to request the letter of technical assistance from the Type Certificate holder and then apply to the MIDO. It really depends on the OEM if they will provide this letter. Some of the larger airframers will give them to the supplier with no problem, others will refuse the request. If you hold the TSO for the part you do not also need PMA. For the less friendly way to get PMA, you would need to show identically through an alternate route such as test and computation. This eliminates the OEM from the equation and you would apply to the ACO. For more information research FAA Order 8110.42D (also on the RGL).
Good luck!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Basic questions about AS9100C Quality Standard Requirements qarep AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3 24th January 2013 08:22 AM
EASA DOA and ETSO (European Technical Standard Order) patricmaurizio EASA and JAA Aviation Standards and Requirements 4 31st August 2011 10:28 AM
Material Qualification for TSO (Technical Standard Order) Authorization INHOKARI Federal Aviation Administration (FAA) Standards and Requirements 6 26th June 2011 08:06 PM
TSO (Technical Standard Order) and PMA (Parts Manufacturer Approval) - Differences AlessandoP Federal Aviation Administration (FAA) Standards and Requirements 5 10th December 2010 01:50 PM
Help With Basic Minitab Questions! pistolpete_1980 Using Minitab Software 6 28th July 2009 03:12 PM
The time now is 08:13 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
