The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions
Forum Username
Wooden Line
Taguchi Design with ANOVA - 3 factors each with 3 levels
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
anova (analysis of variance), evop (evolutionary operation of processes), minitab (statistical analysis software), statistical analysis and studies, taguchi designs and analysis
Reply
  Post Number #1
Old 28th November 2016, 06:55 PM
ShervinA
Please Help! Taguchi Design with ANOVA - 3 factors each with 3 levels
I have a GA code and I want to use the Taguchi Technique as a parameter tuning tool. I have 3 factors each with 3 levels. I used L9 array and I ran 9 experiments and entered the results.
The problem is that I don't get any ANOVA result and no interaction graphs. Would you please help me with this.
Thank you so much in advance.
Shervin
P.S. I attached the Minitab file.
Taguchi.MPJ
Sponsored Links
  Post Number #2
Old 29th November 2016, 11:24 AM
Miner's Avatar
Look! Re: Taguchi Design with ANOVA
Minitab's Taguchi analysis does not provide much flexibility, so I recommend that you analyze this using the GLM analysis under the ANOVA menu. Another option is to define it as a custom General Full Factorial DOE.
Unfortunately, you will find that you cannot analyze any interactions because there are insufficient degrees of freedom to create the ANOVA table.
Thank You to Miner for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 30th November 2016, 07:42 AM
ShervinA
Thank you so much for your help. It means a lot.
I have another question I have projects from a couple of years ago that I used Taguchi in Minitab and the ANOVA is reported during the Taguchi method process, but in this case, nothing more than signal to noise ratios are reported. I thought maybe something is wrong with my data.
I would be really grateful if you help me with this too.
  Post Number #4
Old 30th November 2016, 09:12 AM
Miner's Avatar
In Reply to Parent Post by ShervinA View Post
If you attach the Minitab project file, I'll take a look. While I am quite familiar with Taguchi methods, I rarely use them anymore since I have found classical approaches to be be much better. I will have to review Minitab's capabilities in this area.
Thanks to Miner for your informative Post and/or Attachment!
  Post Number #5
Old 30th November 2016, 11:34 AM
ShervinA
In Reply to Parent Post by Miner View Post
I guess I found the option under Taguchi design analysis as 'Fit linear model'. It didn't work so I used GLM as you mentioned and it worked. Thank you so much. However the r- sq value is equal to 63% and I guess I can't rely on Taguchi result. Do you think considering additional factors will help or Taguchi is not suitable at all for parameter tuning?!... (the Minitab file is attached in the first post)
I appreciate any ideas and thank you in advance for your brilliant ideas.
Thanks a ton!
Sent from my C5303 using Tapatalk
  Post Number #6
Old 30th November 2016, 12:55 PM
Miner's Avatar
Look! Re: Taguchi Design with ANOVA - 3 factors each with 3 levels
I don't like the reliance on S/N ratio. I understand why Taguchi went that route. His methodology was easier in the pre-computer days, and the engineers he was working with were in the telecommunications industry where S/N ratio was prevalent.
I now use classical methods and analyze the mean and standard deviations separately. Minitab adheres strictly to Taguchi's original approach and does not provide the options available under their classical designs.
I recommend using either classical designs, possibly including response surface methods, or an EVOP approach to tuning.
  Post Number #7
Old 30th November 2016, 01:11 PM
ShervinA
Thank you so much for your ideas
To be honest the first time you mentioned classical designs I thought you are talking about DOE full factorial but now that you named response surface and EVOP approach you got me so interested, and I want to learn them. So I'll do some research.
Thanks a lot
  Post Number #8
Old 30th November 2016, 03:12 PM
Miner's Avatar
Don't forget that classical designs include fractional factorials and center points.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
ANOVA for Taguchi method - Four factors and three levels and nine runs (Minitab) eorka333 Using Minitab Software 6 17th April 2014 07:48 AM
Taguchi Design with 6 levels and 3 factors in Minitab yz_rain Using Minitab Software 11 27th March 2014 12:38 PM
Taguchi design for 3 level 4 factors runvar Using Minitab Software 12 4th December 2013 03:33 PM
DoE and ANOVA - 4 factor and 3 levels Taguchi design with 2 replicates cristiano74 Using Minitab Software 14 20th May 2012 06:22 PM
ANOVA - 2 factors with different levels blarifme Using Minitab Software 2 8th January 2010 10:17 AM
The time now is 01:47 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
