The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Forum Username
Wooden Line
Corrective Action for a scenario where Assignable Cause is not confirmed
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
View Poll Results: How to Handle CA-PA when root cause is NOT established/assignable.
A separate CA is not required or relevant. 0 0%
CA, must still be prioritized to the most probable root cause. 7 100.00%
CA and PA are same. 0 0%
Voters: 7. You may not vote on this Poll because you are not Logged In.
Some Related Topic Tags (Not all threads are Tagged)
assignable causes, corrective action (ca)
Reply
  Post Number #1
Old 23rd December 2016, 06:47 AM
v9991
Apple Corrective Action for a scenario where Assignable Cause is not confirmed
by definition,
* CA is ensuring/ arresting the recurrence of problem or root-cause ( process of reacting to product problems, customer
complaints or other non-conformities and fixing them)
* PA is about ensuring other 'potential' recurrence of problems/root-cause. (detecting potential problems or nonconformance's and eliminating
them)
now how to handle CAPA in a scenario where root-cause is NOT- established/assignable.
Sponsored Links
  Post Number #2
Old 23rd December 2016, 07:49 AM
Pancho's Avatar
Pancho
Re: Corrective Action for a scenario where assignable cause is not confirmed.
Here's my take: Corrective and preventive actions are improvements (desirable modifications) to a process. And vice versa - improvements to a process are CA or PA, whether or not they were done formally (through the CAPA procedure). Conversely, if an action doesn't modify a process then it is not corrective nor preventive. I wish this was clear in the standard. It would eliminate a lot of the confusion.
If a NC exists, then there is a root cause. If the root cause hasn't been established, then dig deeper using one or several problem solving methodologies. Once you've established the root cause, then it may be such that you really can't modify your process to eliminate it, perhaps because it would be too expensive or because no one in your team can think of a way of modifying the process. In that case, you may have to live with inspecting the recurring NCs out of the product. But that, itself, can be your CA, as the healing inspections become part of your process and thereby it is modified for the better.
If no NC exists, and you can't establish a root cause for the first occurrence of a potential NC, then maybe you don't need to take preventive action. That means that you wouldn't modify your process.
Thank You to Pancho for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 23rd December 2016, 02:08 PM
PaulJSmith's Avatar
PaulJSmith
If there is indeed a nonconformance, then there is indeed also a root cause of that nonconformance. Something had to cause it. Just because you haven't yet discovered it doesn't mean it doesn't exist. As Pancho noted, you just need to dig deeper, or maybe in a different direction, until you find it. Not until that point can you turn to the task of developing a corrective action for it.
  Post Number #4
Old 23rd December 2016, 03:11 PM
Sidney Vianna's Avatar
Sidney Vianna
Re: Corrective Action for a scenario where Assignable Cause is not confirmed
In Reply to Parent Post by v9991 View Post
If you can't pinpoint the actual cause, you end up with potential cause(s). You then institute preventive action(s) in such preventive cause(s) and the end result should be the same: no repeat NC's.
Thanks to Sidney Vianna for your informative Post and/or Attachment!
  Post Number #5
Old 24th December 2016, 12:53 PM
v9991
In Reply to Parent Post by Pancho View Post
if you meant the product-process-step, .... there are instances where the process (not the product-itself, but the activity, (business-process-step )might have slipped. (relevant more so, from perpsective of a regulated environment perspective, and also from compliance to standard (s))
In Reply to Parent Post by Sidney Vianna View Post
True, if we dig deep, we will eventually figure out the cause; however,
the time-effort spent for such instance where the root-cause might not be always relevant-pertinent to be established,; viz., even in software, there are bugs which are difficult to reproduce.! ref. another example!
Solutions can be re-injected as part of an investigation where a transient equipment malfunction is suspected. Such hypotheses are difficult to prove. However, reinjections can provide strong evidence that the problem should be attributed to the instrument, rather than the sample or its preparation.
Investigating Out-of-Specification (OOS) Test Results for Pharmaceutical Production
i personally feel, that there is an opportunity to see PA as a sub section of continual improvement. ( CI intended to provide positive benefit, and when we see PA as an extension of CI, which eliminates the negative impact of the process.!
Click image for larger version
Name:	3-legged 5-why.jpg
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Last edited by v9991; 25th December 2016 at 12:53 AM. Reason: added quick view of ppt-slide...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
What action when a suspected NC is not confirmed? TWA, not the airline Nonconformance and Corrective Action 4 19th September 2013 07:09 AM
Corrective Action vs. Failure Analysis - Corrective Action for Every Defect Found? Shawn97701 - 2009 Nonconformance and Corrective Action 5 6th December 2007 04:48 AM
How to justify Widened Control Limits - No Assignable Cause scenario wchuey Statistical Analysis Tools, Techniques and SPC 26 10th May 2007 10:57 PM
How to Write CAR (Corrective Action Request) based on scenario AS_QualityEngineer Nonconformance and Corrective Action 3 5th December 2006 04:39 PM
Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action Ace Nonconformance and Corrective Action 6 26th November 2001 01:47 AM
The time now is 06:24 PM. All times are GMT -4.
NOTE: This forum uses "Cookies"
