The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > CE Marking (Conformité Européene) / CB Scheme
Forum Username
Wooden Line
CE Marking - Low Voltage Directive and EMC Directive
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
ce mark and ce marking, emc (electromagnetic compatibility), low voltage directive 2006/95/ec, standards (e.g. iso mdd ansi etc.)
Reply
  Post Number #1
Old 16th August 2016, 05:57 AM
Gkknight27
Please Help! CE Marking - Low Voltage Directive and EMC Directive
Hello just looking for some advice.
We produce heating cable and have a customer asking for CE certificate, I have looked through the low voltage directive and EMC directive and cant find the standard we produce cable too amongst the harmonised standards.
Historically we have never provided CE Certificates from what I have been told. As a product the Cable is then turned into heating units by the end user. Our sister company assembles ATEX certified units so all of these have the correct paper work.
So should I be providing a CE certificate ?
Cheers
Graham
Sponsored Links
  Post Number #2
Old 16th August 2016, 07:44 AM
QAengineer13
Re: Help Needed regarding CE marking
Hi Graham,
After seeing your post my immediate thought about the heating cable was the EN 61010-1 3rd Edition,The scope of the standard is expanded to cover the following types of equipment:
Electrical test and measurement equipment
Electrical laboratory equipment
Electrical industrial process-control equipment
I know you are only a Cable manufacturer, let your customer know that whether will they be able to test your cable in their instrument maybe an IVD or Medical Device.
NOTE:
As of October 1, 2013, compliance with EN 61010 3rd Edition will be mandatory for products needing to comply with the EU low voltage directive for CE marking. The CB Scheme accepted IEC 61010-1 in August 2010. In North America, UL announced the effective date for 61010-1 third edition is January 1, 2018.
Not sure whether this will help, but you have to work with your customer and have them test your cable on their MD/IVD equipment for compliance.
I read this article sometime back, thought this would be of some help with your situation:
Does my product need CE Marking?
CE Marking is most probably required if you export to the 27 European Union (EU) and 3 European Free Trade Association (EFTA) member states the following 20 groups of products -
Appliances Burning Gaseous Fuels (AppliGas)
The "appliances burning gaseous fuels" used for cooking, heating, hot water production, refrigeration, lighting or washing and having, where applicable, a normal water temperature not exceeding 105 gC. Forced draught burners and heating bodies to be equipped with such burners will also be considered as appliances.
The "gaseous fuel" means any fuel which is in a gaseous state at a temperature of 15 gC under a pressure of 1 bar. more >>
Cableway Installations to Carry Persons
The "cableway installations designed to carry persons" shall mean installations made up of several components, designed, manufactured, assembled and put into service with the object of carrying persons.
These on-site installations are used for the carriage of persons in vehicles or by towing devices, whereby the suspension and/or traction is provided by cables positioned along the line of travel. more >>
Low Voltage Electrical Equipment
The "Electrical Equipment" means any equipment designed for use with a voltage rating of between 50 and 1000 V for alternating current (A.C.) and between 75 and 1500 V for direct current (D.C.). Therefore, it is called often "Low Voltage Electrical Equipment" which includes the vast majority of electrical equipment in everyday use. more >>
Construction Products
The "construction product" means any product which is produced for incorporation in a permanent manner in construction works, including both buildings and civil engineering works. more >>
Equipment and Protective Systems for Used in Potentially Explosive Atmospheres (Atex)
Equipment means machines, apparatus, fixed or mobile devices, control components and instrumentation thereof and detection or prevention systems which, separately or jointly, are intended for the generation, transfer, storage, measurement, control and conversion of energy for the processing of material and which are capable of causing an explosion through their own potential sources of ignition.
Protective systems means design units which are intended to halt incipient explosions immediately and/or to limit the effective range of explosion flames and explosion pressures. Protective systems may be integrated into equipment or separately placed on the market for use as autonomous systems.
Components means any item essential to the safe functioning of equipment and protective systems but with no autonomous function. Explosive atmospheres Mixture with air, under atmospheric conditions, of flammable substances in the form of gases, vapours, mists or dusts in which, after ignition has occurred, combustion spreads to the entire unburned mixture.
Potentially explosive atmosphere means an atmosphere which could become explosive due to local and operational conditions. . more >>
Explosives for Civil Uses
The "Explosives" here shall mean the materials and articles considered to be such in the United Nations recommendations on the transport of dangerous goods and falling within Class 1 of those recommendations. more >>
Hot Water Boilers
The "hot-water boilers" here means a boiler fired by liquid or gaseous fuels with a rated output of between 4 kW and 400 kW (including 4 kW and 400 kW). more >>
Lift
The "lift" here means an appliance serving specific levels, having a car moving along guides which are rigid and inclined at an angle of more than 15 degrees to the horizontal and intended for the transport of:
- persons,
- persons and goods,
- goods alone if the car is accessible, that is to say, a person may enter it without difficulty, and fitted with controls situated inside the car or within reach of a person inside. more >>
Machinery
the "machinery" means:
an assembly of linked parts or components, at least one of which moves, with the appropriate actuators, control and power circuits, etc., joined together for a specific application, in particular for the processing, treatment, moving or packaging of a material,
an assembly of machines which, in order to achieve the same end, are arranged and controlled so that they function as an integral whole,
interchangeable equipment modifying the function of a machine, which is placed on the market for the purpose of being assembled with a machine or a series of different machines or with a tractor by the operator himself in so far as this equipment is not a spare part or a tool. more >>
Measuring Instruments
the "measuring instrument" means: any device or system with a measurement function that is covered by Articles 1 and 3; more >>
Medical Devices
A "Medical Device" is defined in Directive (93/42/EEC) as: any instrument, apparatus, appliance, material or other article, whether used alone or in combination, including the software necessary for the proper application, intended by the manufacturer to be used for human beings for the purpose of :
diagnosis, prevention, monitoring, treatment or alleviation of a disease, an injury or a handicap.
investigation, replacement or modification of the anatomy or of a physiological process.
control of conception
and which does not achieve its principal intended action in or on the human body by pharmacological, immunological or metabolic means, but which may be assisted by such means. more >>
Active Implantable Medical Devices
The "active medical device" means any medical device relying for its functioning on a source of electrical energy or any source of power other than that directly generated by the human body or gravity
The "active implantable medical device" means any active medical device which is intended to be totally or partially introduced, surgically or medically, into the human body or by medical intervention into a natural orifice, and which is intended to remain after the procedure. more >>
In Vitro Diagnostic Medical Devices
The "in vitro diagnostic medical device" means any medical device which is a reagent, reagent product, calibrator, control material, kit, instrument, apparatus, equipment, or system, whether used alone or in combination, intended by the manufacturer to be used in vitro for the examination of specimens, including blood and tissue donations, derived from the human body, solely or principally for the purpose of providing information:
- concerning a physiological or pathological state, or
- concerning a congenital abnormality, or
- to determine the safety and compatibility with potential recipients, or
- to monitor therapeutic measures.. more >>
Non-automatic Weighing Instruments
A "Weighing Instrument" is defined as a measuring instrument serving to determine the mass of a body by using the action of gravity on that body. A weighing instrument may also serve to determine other mass-related magnitudes, quantities, parameters or characteristics.
A "non-automatic weighing instrument" is defined as a weighing instrument requiring the intervention of an operator during weighing. more >>
Radio Equipment & Telecommunications Terminal Equipment (R&TTE)
A "radio equipment" means a product, or relevant component thereof, capable of communication by means of the emission and/or reception of radio waves utilising the spectrum allocated to terrestrial/space radiocommunication.
A "telecommunications terminal equipment" means a product enabling communication or a relevant component thereof which is intended to be connected directly or indirectly by any means whatsoever to interfaces of public telecommunications networks (that is to say, telecommunications networks used wholly or partly for the provision of publicly available telecommunications services). more >>
Personal Protective Equipment (PPE)
The "personal protective equipment" means any device or appliance designed to be worn or held by an individual for protection against one or more health and safety hazards. more >>
Simple Pressure Vessels
The "simple pressure vessel" means any welded vessel subjected to an internal gauge pressure greater than 0,5 bar which is intended to contain air or nitrogen and which is not intended to be fired. more >>
Pressure Equipment
The "Pressure Equipment" means vessels, piping, safety accessories and pressure accessories.
Where applicable, pressure equipment includes elements attached to pressurized parts, such as flanges, nozzles, couplings, supports, lifting lugs, etc.
'Vessel` means a housing designed and built to contain fluids under pressure including its direct attachments up to the coupling point connecting it to other equipment. A vessel may be composed of more than one chamber.
'Piping` means piping components intended for the transport of fluids, when connected together for integration into a pressure system. Piping includes in particular a pipe or system of pipes, tubing, fittings, expansion joints, hoses, or other pressure-bearing components as appropriate. Heat exchangers consisting of pipes for the purpose of cooling or heating air shall be considered as piping.
'Safety accessories` means devices designed to protect pressure equipment against the allowable limits being exceeded. Such devices include:
- devices for direct pressure limitation, such as safety valves, bursting disc safety devices, buckling rods, controlled safety pressure relief systems (CSPRS), and
- limiting devices, which either activate the means for correction or provide for shutdown or shutdown and lockout, such as pressure switches or temperature switches or fluid level switches and 'safety related measurement control and regulation (SRMCR)` devices.
'Pressure accessories` means devices with an operational function and having pressure-bearing housings.
'Assemblies` means several pieces of pressure equipment assembled by a manufacturer to constitute an integrated and functional whole. more >>
Recreational Craft
The "Recreational craft" means any boat of any type, regardless of the means of propulsion, from 2,5 to 24 m hull length, measured according to the appropriate harmonized standards intended for sports and leisure purposes. more >>
Toys
A "toy" shall mean any product or material designed or clearly intended for use in play by children of less than 14 years of age
Last edited by QAengineer13; 16th August 2016 at 07:50 AM. Reason: added more information for CE marking
Thanks to QAengineer13 for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 18th August 2016, 02:14 AM
CharlieUK
You can only CE mark if the product is within scope of one or more directive that require CE marking.
Mains voltage cables are within scope of the LVD (see LVD guidance, http://ec.europa.eu/DocsRoom/documen...1/translations)
Also, cables are generally in scope of RoHS (guide http://ec.europa.eu/environment/wast...s_rohs3_en.htm)
Thank You to CharlieUK for your informative Post and/or Attachment!
  Post Number #4
Old 9th September 2016, 05:47 AM
Gkknight27
Re: Help Needed regarding CE marking - Low voltage directive and EMC directive
Thanks a lot for the guidance. It will help me sort the problem out.
Sorry for the delay in my reply, as always something else pops up. This time VDA actions from our customer...... Oh the joys !!!!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
CE Marking - RTTE Directive & IVD Directive mentor09 CE Marking (Conformité Européene) / CB Scheme 7 1st December 2016 12:25 AM
If/how to apply LVD (Low Voltage Directive) in this case jenlianne146 CE Marking (Conformité Européene) / CB Scheme 6 17th April 2015 08:34 AM
CE Marking for LVD (Low Voltage Directive) Health and Beauty Products controlz CE Marking (Conformité Européene) / CB Scheme 5 4th February 2014 06:17 PM
Low Voltage Directive LVD 2006/95/EC - New to CE Marking Satch CE Marking (Conformité Européene) / CB Scheme 4 14th July 2011 09:19 PM
What's the relationship between LVD (low voltage directive) and MDD luloo117117 EU Medical Device Regulations 3 9th February 2009 07:45 AM
The time now is 03:09 AM. All times are GMT -4.
NOTE: This forum uses "Cookies"
