The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > CE Marking (Conformité Européene) / CB Scheme
Forum Username
Wooden Line
Class I Medical Device into a higher class (IIa or IIb)
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
class i medical device, class ii medical device, medical devices
Reply
  Post Number #1
Old 31st August 2016, 04:55 AM
MDD_QNA
Question Class I Medical Device into a higher class (IIa or IIb)
Dear all,
What would be the reason to buy a product that is of class I and make it into a class II device? I have been asked to look into this matter. We have a pharmaceutical (lotion) that is used together with a lamp. This lamp is a class I device right now. And I am looking into what the requirements are to make it into a class II device.
Will the new regulation have any effect on the matter?
I have no idea about this lamp as for now.
Very grateful for your input!
Sponsored Links
  Post Number #2
Old 31st August 2016, 05:00 AM
Ronen E
Re: Class I into a higher class (IIa or IIb)
If a given device is classified properly, there is no way you can force-classify it into another class unless you change its design or its intended use.
What would your company gain from having the lamp classified as >1?
Sponsored Links
  Post Number #3
Old 31st August 2016, 06:40 AM
MDD_QNA
Please Help! Re: Class I Medical Device into a higher class (IIa or IIb)
Ok, so the design will remain the same and we will add one indication to it. It will probably become a class IIa device, so what are the requirements compared to class I, when it comes to documentation?
Probably 60601-testing and EMC, particular 2-57, clinical data, IFU/label update. What else?
Edit: right now the lamp is used as an overhead lighting for surgery and it will have a new intended use of treating a disease.
  Post Number #4
Old 31st August 2016, 11:01 AM
mihzago
Clinical data is required for all classes, see MEDDEV 2.7/1 rev. 4.
You will also need a Notified Body involvement to review your tech file and issue the EC Cert.
there may be other things.
Thank You to mihzago for your informative Post and/or Attachment!
  Post Number #5
Old 31st August 2016, 08:15 PM
Ronen E
In Reply to Parent Post by MDD_QNA View Post
With all due respect, I think that your approach isn't right.
In the EU (which I assume is your regulatory context in this discussion) class I devices and class IIa devices are treated quite differently. My advice - forget that the lamp was ever classified as class I. Look at it as it is, with the newly added intended use, and analyse your regulatory situation accordingly. Study the relevant MDD requirements and verify that all are met. Some will already be covered as part of the class I compliance, but the gaps are likely to be significant.
Probably the biggest difference is the obligation to get a NB involved.
Thanks to Ronen E for your informative Post and/or Attachment!
  Post Number #6
Old 1st September 2016, 05:33 AM
MDD_QNA
Question Re: Class I Medical Device into a higher class (IIa or IIb)
And how do we determine what annex to follow? A similar device we have we use Annex V and VII.
  Post Number #7
Old 1st September 2016, 05:38 AM
MDD_QNA
In Reply to Parent Post by Ronen E View Post
What is the GAP in terms of documentation? What is the difference in documentation requirement?
  Post Number #8
Old 1st September 2016, 09:00 AM
Ronen E
If indeed the lamp is classified as IIa, and you don't actually make it or physically change anything in it, you could probably do with Annex VI instead of Annex V (and it's a little less burdensome). You could, however, keep it under Annex V and exclude the parts that are not relevant.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Electrical Class (Class I, II & III) vs. Medical Device CE marking Class I, II & III LuckyK ISO 13485:2016 - Medical Device Quality Management Systems 3 6th January 2015 12:43 PM
Device Class when used in combination with a device of a higher class? icare2much 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11 30th July 2012 01:58 PM
Can a Predicate device be a higher class? Sheppi76 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8 20th July 2012 10:15 AM
Change Medical Device Class from Class II to Class I AJayC 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8 2nd December 2011 04:39 PM
Medical Device Registration Process in Italy - Class I and Class II Medical Devices ISO 13485 - Medical ISO 13485:2016 - Medical Device Quality Management Systems 2 21st May 2011 03:05 AM
The time now is 03:54 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
