Configuration Management Basics - AS9100
K
Koivisto - 2009
I work for an electronics firm that is ISO/TS certified. We are working towards including AS9100 and I know there is a revision coming soon. I am trying to figure out configuration management. Can I meet the intent and requirement by making a process flow of how everything works from start to finish? We buy wire and connectors and then assemble.
K
Koivisto - 2009
Re: Configuration Management
Then I post and scroll down and see the same question! I'm not worthy!
Wes Bucey
Prophet of Profit
Don't beat yourself up - Configuration Management confuses many folks. Look through those threads plus use the advanced search function here in the Cove to look up "Configuration Management" - you may be "enlightened" to find a more complete definition and some interesting examples to help you understand the philosophy and activity involved in Configuration Management.
Afte you do that little bit of research, add another post in this thread with any new questions you may have about CM.
W
w_grunfeld
If all you do is wiring harnesses (built to print or your won designs? )CM should be very, very simple. In a nutshell, all it is ,controlling the revisions of your engineering drawings (and other controlled documents) and making sure you manufacture in accordance with the correct revision of drawings.
It gets complicated for organizations with many different designs and different models, frequent design changes and so on, software with many different versions and so on.
I am not sure you can explain your system by a process flow. Just write a procedure explaining how do you revise and control engineering changes and make sure that products are assembled per the latest revision.
Wes Bucey
Prophet of Profit
Actually, Configuration Management is a little more involved than just shuffling papers to make sure you are using the current version of a document. See Configuration Management - Part history - How to record changes"] for brief picture of just "some" of the activity which Configuration Management entails.
W
w_grunfeld
Hi Wes,
Thank you for the link but trust me I don't need it, I am not the one asking what CM is- I have run Configuration Management programs for Weapoon Systems involving both hardware and software in compliance with the now defunct MIL-STD-973 and it's a bit moe complicated even than what's described in the link you provided...
However Koivisto wrote:"We buy wire and connectors and then assemble"
So why complicate him with things he doesn't need?!
Wes Bucey
Prophet of Profit
Hi Wes,
I can think of at least a dozen things to complicate wire harness assembly - I bought a number of them for aerospace/commercial aircraft. Different harness requirement for each aircraft type, for each accessory/replacement part within type. Material supplier, pricing, confirming gage, measuring length, color and rating of insulation, different size tooling for different connectors, setup on wire stripper for amount of bare wire, crimp or solder connections, type of solder, employee work instructions for specific harness type, training of employee, evaluation of training, pull test on connectors, flex test on wire and insulation so it won't crack in use, packaging requirements, mistake proofing assembly table setup, functional testing for resistance, fireproofing, documentation, installtion instructions, etc. etc. etc.
My point is: Good configuration management considers ALL those things before each and every version is put into production to ascertain whether they need to be changed/revised as well. One cannot ASSUME all other segments of the process will remain the same. It is NOT a clerk's job - it requires someone with an overview and understanding of the entire process flow from material selection and acquisition to final installation of finished assembly.
W
w_grunfeld
What can I say, if you lump together purchasing, design, manufacturing ,quality and even pricing as all being CM, than we must be speaking of two different things.
All the factors you have mentioned are very important, however they concern 5-10 different disciplines (depending on company size) very few of which are CM issues
My view is more "limited" and I subscribe to CM being "just" as defined in ISO10007, ANSI/EIA-649 and MIL-STD-973 do, none of which deal with the crimping tools or wire gages....
Btw, whom are you aluding to as thinkig CM is clerk's job?
Or do you consider writing a CM procedure being a clerk's job?
I thik we must have scared off our fellow cover Koivisto with our argument.
All I meant was to tell him that a procedure was a more effective way than a flowchart, to document the way they control design changes (if they design at all, they are more likely just contract manufacturer) and how they assure the product configuration matches the documentation. IN A NUTSHELL THAT'S ALL THERE IS TO CM IN THIS CASE
Yes they also need a route card, workmanship standards and more but that has nothing to do with CM, EXCEPT THAT THEY NEED TO BE CONTROLLED
K
Koivisto - 2009
You guys didn't scare me off! I was beating my head against the wall trying to wrap my mind about what was really required and how to make sure we will be effective. I have found over the years to make the standards work for you and not to write something just to please an auditor. It makes for "no fear" audits and improves the company. As you both probably know, a good percentage talk the talk but don't walk it. I have studied this site and the internet and wrote the procedure. I commend both of your insights and disussions, that is how to really learn! No questions leads to no answers!
wayne.wilson7
Hi all I am new to the forum
Reading through so many threads on here am i right in saying CM is about Drawing Issue, Process Issue control etc.
I work for a Sub-Contract Company in the uk in which we work to Customer supplied drawings, we do not design or draw anything. On reciept of a customer order which is entered onto our own developed software we referance order numbers, drawing numbers issue numbers etc so we do not raise any change requests, we just rely heavily on our contract review to ensure processes, drg issues are correct to the drg supplied.
Thanking you in advance for your Help
Wayne
