The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Manufacturing, Service, and Business Systems Processes > Human Factors and Ergonomics in Engineering
Forum Username
Wooden Line
Eliminating Missing Steps In Manual Operations
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
human error, manual operations
Reply
  Post Number #1
Old 31st July 2013, 09:45 AM
jfbock
Please Help! Eliminating Missing Steps In Manual Operations
I know this may be a difficult issue and probably has been from the beginning of time but here it goes.
In our case, not often but once in a while our fabricators miss a weld. I would guess human error is to be expected but our customer simply has no tolerance for it. One solution is 100% inspection, but that's stop gap and isn't addressing the core issue.
Aside from converting to robots (not an option) what suggestions or methods are out there that may be helpful?
Sponsored Links
  Post Number #2
Old 31st July 2013, 10:12 AM
Mikishots's Avatar
Mikishots
Re: Missing Steps In Manual Operations
Something to consider: Add accountability, with more granulation in the flow inspection points. Have two lines for sign-off in the work order line: one for the operator, one for the verifier (usually a charge-hand or QC inspector). This will identify where the failure is occurring and the methods that aren't working.
You didn't mention if the part goes from Weld to another area for further processing, or if it goes directly to the customer. If it's the latter, then the final inspection step isn't effective or doesn't exist. If it's the former, the group receiving the part should always be verifying the previous step. If it hasn't been done, the part is simply returned to the previous cell for completion.
Thank You to Mikishots for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 1st August 2013, 05:43 AM
harry
Re: Eliminating Missing Steps In Manual Operations
Some ideas from this thread could be useful for you: How to Avoid Missed Welds - Job shop and weld several small quantity jobs
Thanks to harry for your informative Post and/or Attachment!
  Post Number #4
Old 25th November 2014, 06:22 AM
pinkrosi
So was wondering if there was any other scientific approach to identify needs based on which a communication model can be developed which clearly identifies 5W 1H of the communication to be done.
adil
  Post Number #5
Old 25th November 2014, 10:48 AM
cbehrens
There are weld monitoring devices capable of counting welds during the process.
Arc Agent is a name that comes to mind. Sure there are others just one that I have experience with. No affiliation just a past customer.
  Post Number #6
Old 25th November 2014, 05:21 PM
Bjourne's Avatar
Bjourne
I'd like to share my experience with the same issue some years back when I was with car manufacturing plant. The area was where we manufacture steel made re-usable pallets that are used for stacking/shipping automotive transmissions to Asia. During training there was a piant-pen that we use to mark the weld location after we had finished welding that particular portion. That part was to train the welder to inspect what he had welded. It worked for a time until the welders marked the welded part even when they did not actually checked it. Worse was after training the paint marker was removed and as the welders became accustomed to the work the became complacent and it paved the way for non-checking.
From there we would have missed welds or in most cases welds that are not good/proper. The end users have pointed the defective parts to use when the pallet arrived at Malaysia/Thailand with supports broken because one end seemed not to support the whole load. The broken pallets was shipped back to us with the photos identified as weakpoint etc. We saw it all. We have traceability codes to determine what shift and who was/were the welder/s but that is a different issue( retraining and suspension etc). This is where it is tricky because even if the guilty welder says he had inspected/checked the welded portions properly there was in no way that we can be sure prior shipment so we had added a station just for weld final inspection. So there was an assigned inspector just to inspect the welding 100%. Complete with a map for checking/inspection guides plus tools to check if the weld is stable. That weld map checklist was also crucial when we had to evaluate who was prone to poor welding on what weld location on what station. We even plotted it in a graph for every welder to see so they know where they stand. That is also a key factor why on that particular weld location this welder welds poorly, at what time/shift.
This was also included in a Quality Circle project which was to eliminate weld misses/poor welds. A lot of improvements came from it. The lighting, space, improved visual aids/keypoints at every station, rotating welders so that they may not be complacent in one location/station...environment improvement..etc. But as mentioned earlier the best solution that we had at that time was an additional inspector outside those welders. An additional inspection procedure aside from the welders inspection procedure. There was also a strike out penalty so if a welder has found to be re-miss on his welding quality there was an appropriate penalty. It still is the same until today except that they are now shifting to robotics slowly.
Thank You to Bjourne for your informative Post and/or Attachment!
  Post Number #7
Old 26th November 2014, 03:05 PM
Mikishots's Avatar
Mikishots
In Reply to Parent Post by cbehrens View Post
This won't help with missing welds - it's used to identify welds made that are outside specified parameters. The system can't flag something that never existed in the first place.
  Post Number #8
Old 26th November 2014, 03:30 PM
cbehrens
I'm sorry but you are mistaken. It is also capable of counting welds. Please see the first case study.
http://www.impactwelding.com/arcagen...inmenu-83.html
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Revision History of Quality Manual Missing kilas78 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12 13th September 2014 10:20 AM
ISO 9001 Quality Manual for an O&M (Operations and Maintenance) Company Nivedita M ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14 25th August 2014 02:56 PM
Eliminating a Recurring Problem of Missing Weld Nuts/Fasteners Laser Manufacturing and Related Processes 27 3rd December 2009 11:24 PM
Business Operations Manual & Quality Management system lungi23 Quality Management System (QMS) Manuals 6 24th April 2009 12:40 PM
Quality Manual missing information - Root cause for a documentation mistake rharold Problem Solving, Root Cause Fault and Failure Analysis 15 6th March 2007 01:18 AM
The time now is 04:18 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" - A Peachfarm Internet Property
