The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Manufacturing, Service, and Business Systems Processes > Human Factors and Ergonomics in Engineering
Forum Username
Wooden Line
What is the typical industry standard for documenting Usability Risk?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
Quality Digest
Some Related Topic Tags (Not all threads are Tagged)
iec 62366 - medical device usability engineering, usability risk
Reply
  Post Number #1
Old 14th April 2015, 07:12 AM
ryannh
Question What is the typical industry standard for documenting Usability Risk?
With the recent release of IEC 62366-1 what is the typical industry standard for documenting usability risk? Are companies starting to turn towards using the FMEA process? Other than the IEC 62366 are there any good resources for ensuring that you are capturing everything?
Sponsored Links
  Post Number #2
Old 14th April 2015, 08:10 AM
kreid
Re: What is the typical industry standard for documenting Usability Risk?
We use 14971 and 62366.
In my opinion 62366 is well written and therefore usable. The -1 draft also looks like a good improvement which we will adopt.
Thank You to kreid for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 14th April 2015, 08:12 AM
Jen Kirley's Avatar
Jen Kirley
Welcome to the Cove!
The addition of risk management in IEC 62366-1 is also happening in ISO 9001:2015 and similar questions are being asked.
In both standards there is no default format for documenting risk assessment. I often suggest FMEA because there is a great deal of documentation and instruction on that format. If applying the FMEA format I would consider not limiting to three existing factors (severity, occurrence and detection) but would add more factors and change the occurrence and detection to suit your needs. I suggest including a column for regulation and make this a default for Significant status; the Severity factor, which I would keep, could also trigger Significant status.
The most comprehensive and usable examples I have seen added columns to list applicable regulation(s), one for applicable operational control procedure(s), one for monitoring method(s). An additional set of columns could be added to show the effect on risk by actions taken to mitigate through improved operational controls. It is especially important to be able to point to the engineering changes done to lower Severity. I would add a Date column showing when it was done, and/or a reference number/name of a record for the applicable project to lower the risk.
I hope this helps!
Thanks to Jen Kirley for your informative Post and/or Attachment!
  Post Number #4
Old 14th April 2015, 08:13 AM
ryannh
KReid, Thanks for the response. I think I should have been more clear in my question. Do you do a usability risk analysis along with product/process risk analysis or is it built into the product/process risk analysis?
  Post Number #5
Old 14th April 2015, 08:28 AM
Jen Kirley's Avatar
Jen Kirley
In Reply to Parent Post by ryannh View Post
If using Excel, an additional column could be used to indicate usability/process and sorted when the user wants to only view usability risk analysis.
  Post Number #6
Old 14th April 2015, 08:46 AM
Jen Kirley's Avatar
Jen Kirley
I would also add that automotive uses a Design FMEA, in which Severity criteria are specific to usability. Other factors might also be different, as appropriate for usability.
  Post Number #7
Old 14th April 2015, 12:27 PM
Statistical Steven's Avatar
Statistical Steven
Usability analysis is separate from process and product risk. Both are usually documented in the risk file, but risk assessment based on 14971 alone is not enough. Another document to look at is ANSI/AAMI HE75:2009
Thanks to Statistical Steven for your informative Post and/or Attachment!
  Post Number #8
Old 14th April 2015, 05:05 PM
Marcelo Antunes's Avatar
Marcelo Antunes
A table such as the one in the attached document is what ISO 14971 (and IEC 62366) requires (I include the sequence or combination of events which is not formally required but makes sense in including)
If you use any hazard analysis technique such as FMEA, FTA, etc, you need to use the result of those to populate the ISO 14971 summary (as they do not have all the information required by ISO 14971).
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Thank You to Marcelo Antunes for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Link between Risk Management, Usability Engineering and R&D in Medical Devices Marcelo Antunes ISO 14971 - Medical Device Risk Management 2 8th March 2015 09:20 PM
What are typical Acceptable Quality Levels (AQL) adopted in Food industry? sabrinalim Food Safety - ISO 22000, HACCP (21 CFR 120) 1 19th April 2013 11:02 PM
IEC 62366:2007 - Is FDA Usability Engineering Standard a Requirement in Canada? melaniewalls Canada Medical Device Regulations 5 4th February 2013 09:46 AM
Usability standard IEC 60601-1-6 in the Medical Device Industry Sanne IEC 60601 - Medical Electrical Equipment Safety Standards Series 4 10th July 2007 07:26 AM
Standard Causes of Registration Audit Nonconformances and Typical Failure Modes TownDawg IATF 16949 - Automotive Quality Systems Standard 5 22nd July 2004 05:18 PM
The time now is 01:10 AM. All times are GMT -4.
NOTE: This forum uses "Cookies"
