Ron Tollett
hi Team, looking for a sample of a Return Material Authorization (RMA) metrics? Much appreciated.
I have an additional question on this. ISO/TS 16949 requires you to track Return Analysis cycle time. First, I can't seem to put my finger on which clause requires this. Second, is there an industry standard for what to use for cycle time? Is it the date you are notified, the date you receive the parts? Then on the end, is it when you contact the customer with the results or when you actually send a final report? For issues that keep requiring more analysis, what do you track?
The organization shall analyze parts rejected by the customer's manufacturing plants, engineering facilities and dealerships. The organization shall minimize the cycle time of this process. Records of these analyses shall be kept and made available upon request. The organization shall perform analysis and initiate corrective action to prevent recurrence.
NOTE Cycle time related to rejected product analysis should be consistent with the determination of root cause, corrective action and monitoring the effectiveness of implementation.
this method is same as our companyHi Ron,
I would like to contribute .
I would suggest two related to the effectivess and efficiency.
One could be the rate of RMA on the product sold to the customer, another could be related to the responde time in case of an issue that caused a material return, for istance to respond to non conformity generated according to the problem solving method/process agreed with the customer in a certain time base ( 1 working week for corrective action plan , 24 hrs for containment etc...).
Hope this helps
